Question about HP Computers & Internet
Our daughter was not feeling well and lost her
Our daughter and lost her grip on her HP G60-232DX laptop. It dropped to the hardwood floor and the glass cracked. It lights up but the desktop looks like shattered shards of glass. If I buy a replacement for the screen, how difficult would it to be to replace the screen myself? What should I look for? What else should I be checking for damage?
    Problem Solver:
  • 16 Answers
It isnt hard at all to do. There are many walk throughs online to guide ya through. Just take your time and have patience. Other things you should look for (that i can think of) can only really be determined after you replace the lcd screen. Dropping a laptop like that can damage the hard drive and therefore losing data or your operating system.
Posted on Jul 21, 2010
How do I fix a squeak in a hardwood floor
squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
Jan 03, 2017 | Vacuums
Which is better between hardwood floor or laminate floor??
I think.. hardwood is much better than laminate wood flooring, but each type of flooring has its advantages and disadvantages. Hopefully this article can help you to choose the floor you want.
Main Differences Between Hardwood And Laminate Flooring
Jul 31, 2015 | Building Materials
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
Does laminated floor look like real wood?
Absolutely, using photographs, laminates lock in the realism of hardwood strip. Nowadays, laminate floors offer an unparalleled level of realism making the floor look like real wood.
Jan 10, 2013 | Building Materials
Dropped my remote on floor and now no buttons work
your batterys probably got loose inside the remote. take the battery cover off and push them back into place.
Jul 13, 2012 | Samsung TV Remote Control
I accidently dropped my HP G71-340US notebook laptop approximately 2 feet hitting the hardwood floor. It was closed and hit the front corner. It sill works fine except all pictures have a grainy, swirling...
you have probably damaged the screen itself, try using it connected to an external monitor, if you have a good picture then your screen needs replacing
Apr 09, 2011 | HP Computers & Internet
Hardwood floor cleaner
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
Apr 19, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Floor nailer, 2" nail not going into harwood
sounds like a bent shaft has the driver had any nail stuck or came out the side? whats the presser on?Are you nailing over exiting floor such as v.c.t or other hardwood floor try a couple drops oil in the nailer i' ve been doing floors for over 30 years these are some of the problems i came across hope its helps some what
Dec 23, 2008 | Farberware Manual Hardwood Flooring Nailer...
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
