Question about ATI RADEON 7500 (64 MB) PCI Graphic Card
Hardware transformation and lighting
How can i get a free copy of hardware transformation and lighting??Please help me solve my inquiry
  • 42 Answers
T&L stands for Transform and Lighting. In earlier days, T&L operations were done by the CPU, which limited the game's geometrical complexity quite a bit and limited developers' creativity while creating environments.
A T&L capable card is one that contains two separate engines for Transform and Lighting operations. So the CPU is not stressed with the task of doing T&L operations and developers can create better artificial intelligence and physics using the freed CPU power.
Transform performance determines how complex objects can be and how many can appear in a scene without sacrificing frame rate. Lighting techniques add to a scene's realism by changing the appearance of objects based on light sources.
It's built into the card or not there's no way to upgrade to T&L plus certain games require T&L version like v1.0, v2.0 graphics cards. Best bet is if you can't play a game that supports T&L is to buy a newer card that supports it.
Hope this helps. M~
Posted on May 02, 2008
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
May 25, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
2 lights. 2 switches and a buzzer. how to connect them to make the buzzer sound when a light is turned on
Copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer-300.jpg
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Above illustration assumes that buzzer is rated for 120Volts.
If doorbell buzzer is rated for 12-24 Vac, then copy following links:
http://waterheatertimer.org/images/3-way-circuit-with-buzzer2-300.jpg
You need contactor with 120Volt coil. The light switches turn on light. At that moment, power goes to 12-24V doorbell transformer from hardware store. At same moment, power goes to magnetic coil on contactor. The contactor is a switch, and it connects wires between transformer and the doorbell buzzer. Buzzer turns ON.
When light turns off, buzzer turns off.
http://waterheatertimer.org/H230A.html
Apr 17, 2013 | Electrical Supplies
How can i download free drivers audio of fmv-biblo nb50j? please help me
Hi
I gave this solution before for laptop drivers , but its actually solve 90% of Driver Problems...
you can expand Start menu then right click in my computer thin choose properties, choose hardware Tab then Device Manager -> and click in device you need to install driver for it -> choose details Tab and copy the Hardware ID thin past it in this site and make search ...
I guess it will helps you.
Apr 24, 2011 | Computers & Internet
Source tray opens, however, none of the target trays open
In order to solve your problem, please answer the questions below:
1) Does the drive(s) light up when the unit is powered on?
2) Does the unit respond when the eject button on the front of the drive is pressed?
3) Does the drive burn during the copy process?
Admittedly, this can be a simple or complex problem. If you would like, please give us a call @ 877-686-8868 x208 for technical support. Thank you for your inquiry and thank you for purchasing EZ Dupe products.
EZ Dupe Technical Support
Oct 20, 2010 | EZ Dupe 3 Target 16x DVD Duplicator...
How to make transformers war for cybertron work on HP windows vista?
Check your System compatibility from here. If its not compatible then you have to upgrade our Hardware. Game is compatible with Windows Vista
Please rate the answer if it helps you to solve the issue :-)
Thanks for using Fixya!
Jul 19, 2010 | Microsoft Windows Vista Home Premium with...
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
No power light - there is power from the transformer
Please check the power cable of the printer and look for light indicator if theres a light indicator on the cable it means cable is roking fine (You can see the light indicator of the cable on the cable itself near on the power socket of the printer
Now if theres a power light on power cable., Please do not use the transformer. Please used the wall outlet or direct the power cable of the printer onto walloutlet socket
If this issue did not solve call kodak for repair toll Free 1 800 235 6325
Nov 02, 2009 | Kodak ESP 5 Printer
Question about video hardware T&L
Hey there.
Please see http://en.wikipedia.org/wiki/Transform_and_lighting , since the Geforce 256, T+L has been included in Nvidia cards.
Hope this helps :-)
May 14, 2008 | Computers & Internet
ATI RADEON 7500 (64 MB) PCI Graphic Card Logo
587 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
