Question about Video Game Consoles & Games
The pump seal is leaking and i want to replace seal
    Champion:
  • 268 Answers
Please specify
Posted on Apr 22, 2008
Onga 4352 Spa Pump is leaking from the opening in the bottom of the pump. I have opened it & siliconed the Oring seal but it continues to leak. Any suggestions?
I had a new pump brought to me once that continued to leak after replacing the shaft seal three times. Careful examination revealed a sand casting fault in the pump body. The water was leaking through the body of the pump. Have you replaced the shaft seal?
Nov 04, 2014 | Plumbing
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
I replaced emerson 1hp pump to my hayward max pump and leaks any ideas all seals replaced
Hi, this is John the Hayward tech. Sounds like the mechanical seal is leaking. If you replace the spring loaded seal the problem could be that it was installed backwards. It is ceramic against carbon. if installed the other way it will leak. Any debris or oils getting on the seal will also cause it to fail Running pump without any water will heat up the seal and cause it to fail.
Jul 21, 2014 | Hayward Pool & Spa
How do I repair a leak coming from water pump gasket?
If it's leaking from the gasket you'll have to replace the gasket. If coolant is leaking from the hole in the water pump body the water pump seal is leaking. The pump will have to be replaced if the seal is leaking.
Sep 12, 2013 | 1999 Plymouth Voyager
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
Oil leaking trans 1999 chevy S10 replaced torque converter seal leaks at front
ou may need to remove the front pump and replace the seal on the pump and the converter seal as well
Aug 08, 2012 | Cars & Trucks
I replaced the motor on my super 2 pump with a new shaft seal. Put it all back together including electrical and now it's leaking from the bottom. I retightened the screws to make sure they weren't loose...
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Sep 18, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Leaking from pump, is it usually the o-ring or something else?
Replacing the entire pump for a broken / leaky seal is a bit overkill - kinda like being advised to replace an engine when its your oil filter seal leaking. Poolcenter.com sells a Polaris "Go Kit" consisting of the three primary o-rings/seals that need periodic replacement as they dry-out and crack, promoting leaks, during non-operating months. Its called the Go-Kit 71 (for about $15.00) plus shipping. Replacement is fairly straight-forward if you know how to disassemble the pump - not rocket science but definately engineering.
Jun 29, 2009 | Polaris Pb4 - 60 Booster Pump
Leak between seal plate and pump/strainer housing
The pump seal is leaking and needs replacing and requires removing four 3/8 bolts (9/16) wrench and removing the motor then the diffuser to get to the impeller and seal . A 7/16 wrench holds the rear motor shaft behind the springs and impeller spins off to reveal the seal which has two parts one on the impeller with a spring and one in the seal plate is white ceramic/ porcelan whatever they use. Part number is an SPX1600KA on super pumps and 1500KA wassome above grounds. When replacing do not touch the mating white and black surfaces with your fingers.
May 25, 2009 | Hayward 1HP Super Pump II Inground Pool...
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
