Question about Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV
TV will not come on, LED light flashes 10 times, then pauses, then repeats Sony Model KDP 57ws655
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Posted on Jul 28, 2010
Mysony wega KDP-57WS655 press power button straight to standby flashing 10 times
Indicates a problem with the high voltage circuit. You could try unplugging the power cord, plug it back in and try again. If that doesn't work unplug the power cord again but leave unplugged for at least five hours and try again. Still doesn't work find a local repair shop that works on sony tvs and have them fix it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
Picture went out and red light on the stand by button blinks ten times and stops for sec and starts the ten blinks all over. When I turn TV on I can hear sound of the tv trying to turn on but no sound or...
10 blinks on KDP-57WS655 model no. is an error code for "High voltage protection". I can tell you exactly which part gone bad and assist you to fix it yourself. Click it here.
Jdvillanueva
Sep 29, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
Model KDP 57WS550. the led flashes 10 times when i turn the tv on and 5 times when i turn it off. what could be the problem?
We have good news and bad news ;)
The bad news is that the 10 blinks you see usually indicate a failure of the circuit boards and you will need a diagnostic visit from a technician to figure out exactly which IC or board has gone bad. It's probably something on the board that controls the magnets that control one of the CRT "guns".
The good news is that, if parts are still available for your unit, it's certainly cheaper to repair than to buy a new LCD LED TV, especially one as big as yours.
You should call Sony for the name of repair companies in your area. A diagnostic visit from their rep will usually run about $150 in the US. They'll take that amount off of the total bill if you go forward with the repair. Replacement of the video IC boards run about $250 each in parts, plus the initial $150 labor charge, for a total of $400 for a typical repair. If they can't fix it, you're only out the initial fee.
Beautiful TV, BTW. Good luck!
Mar 25, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony wega model No. kdp-57ws655 wont pwr on and standby flashes seven times over, and over ?
Hi:
This is a problem with the D-Board, or deflection board as we call it, there are two Ic's that needs replacing that has failed. They are power controller Ic's on the deflection board.
Dec 23, 2010 | Sony Grand WEGA KDP-57WS655 57" Rear...
When turning power on it goes right off led light on front flashes ten times then pauses then flashes ten times again mod# kdp-57ws655 ser# 9709614
It needs repair, Flashing of red light indicates faulty on the circuitry. Power supply or high voltage is faulty. Common cause is a defective PWM IC. MCZ3001d on power supply or high voltage section. Replace those parts and its done...
Nov 13, 2010 | Sony Televison & Video
My sony wega 50 inch tv the standyby light is flashing 9 times and the tv won't power on, whats Up? model number KDP-57WS655
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 10, 2010 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Tv does not turn on
Diode D6116 or D6301 is open on the D board replace those two diodes.
May 22, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV Logo
716 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
