Question about Traxxas Rc Revo Nitro Monster Truck
Front wheels turn opposite of the back wheels
I just changed my front bulkhead and now my front wheels tur[n opposite of my back wheels
Maytag dryer model model MDE6200AYW the heat don't work
this is an electric dryer,first thing to do is on the back where the cord connects to the dryer,make sure you have 240 volts coming to the dryer,if you do unplug the dryer,open the door and remove the four screws,two that hold the door on and the other two opposite the door screws,pull off the front panel,with a 5/16 inch nut driver or socket remove the screws holding on the bulkhead,if you start on the left side i believe the bottom screw has a cutout in the metal,remove that screw,then look at the right side half way up,you should see another screw with the cutout in the metal,remove that,then remove the very bottom screw on the right and remove the other screw opposite the one on right in the middle on the left side,then remove the two on top with the L bracket that holds the top down.any other screws in the bulkhead leave them there,they hold the two panels of the bulkhead together so you don't want to take all the screws out.lift the bulkhead up and out,you have to lift the top panel up a little to do this,then you'll see a metal clip on the right bottom holding the wires to the frame,pull that off,and move the bulkhead to the right with the wires still connected to it,reach in and remove the belt and drum,while you're in here get a shop vac and vac up all the lint,set it up to blow and blow the motor off and blow all the lint out of the heater box,once you get that cleaned out in like 12 months you can unplug the dryer,remove the front panel and blow all the lint out with the drum still in there to keep the lint out of the motor and heater so you don't have a fire and the motor will last longer.also with this dryer,if you remove the front cover to the blower wheel housing you can stick a leaf blower in there and clean out the vent line too,you'll see the hole that the air blows through just stick the leaf blower in there and blow,this way you don't have to pull the dryer out,remove the vent line to clean it out.you want to do this also because if you have a bad thermal fuse it will keep popping if the dryer isn't cleaned out,if the dryer is clogged with lint it runs to hot and the thermal fuse or high limit t-stat will pop and will have to be changed out.now with your meter you want to check the thermal fuse,this is the white part with two wires going to it on the blower wheel cover part WP33001762 you want to remove at least one of the wires,set your meter at 20k ohms,touch the two leads to the part where the wires connect to the fuse,if you see 1 on the meter the part is bad or open,if you see anything else but 1 the part is good or closed,it's that easy to check these parts,if that's good go to the heater box,remove one of the red wires going to the heater and then check it the same way,if that's good check the t-stats on the heater box,you should find that one of these parts are bad,the only other things it could be is the timer or motor but usually it's not one of those.hope this helps you out,if you need any more help write back,also could you just let me know you got this,i answer people and like one out of 20 write back,i just want to know you did get this thanks.
Feb 22, 2018 | Maytag Dryers
Replaced clutch got trans back in car with the car in gear and car in the air you can turn the tires is this correct
Yes you can spin the wheels, unless you've got a locking center chunk, one wheel will turn forward and the other will turn opposite. Front wheel drive or rear wheel drive will do the same.
Aug 06, 2017 | Cars & Trucks
Changed front end parts, front diff fell out . now back together and front wheels spinning opposite of rear wheels.
Drive it on the ground. See what happens. On a lift the tires can and do spin in opposite direction.
Nov 13, 2016 | Cars & Trucks
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
Replace blower belt
unplug it,open the door,remove the two phillips screws that hold the door on and remove the other two on the other side,remove the door and pull the front panel off,just tilt the top of panel out,remove the four 5/16 inch screws that hold the front bulkhead on,then remove the top screws and the L bracket on top,remove the front bulkhead,pop off the metal wire holder on the right side and stick the bulkhead on the right side of the machine so you can remove the drum,lift the top panel up a few inches and slide out the drum,you'll see the mark on the drum from the old belt,put the belt on the drum ribs down against the drum,slide the drum back in,grab the belt,put it under the belt pulley,pull the pulley over to the motor and connect the belt on the motor shaft,put the dryer back together the same way you took it apart,you'll notice two short screws,they go into the holes that have a space around the hole,one goes in the bottom and then the other opposite side up top.hope this helps.
http://www.youtube.com/watch?v=1eeJvqhHEYY
May 16, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
My Maytag LDE9804ACE has a loud squeal when first turned on. The squeal disipates after a few minutes. Any answers? Can I fix this myself?
This could be your drum rollers, or (less likely) your blower wheel. depending on how handy you are, you can change the rollers yourself. After you make sure that the dryer is unplugged, take the door off by taking the screws out, leaving the hinges with the door. the door lifts up slightly and tilts out. then remove the screws from the opposite side of the opening to remove the "front panel". after the screws are out, the panel hinges at the bottom of the unit. Next you have the "front bulkhead". This is held on by 5/16" screws. There are 4 of them, also the door switch is attached to this part and must be carefully removed before taking the bulkhead off. Next is the drum. this just lifts up slightly and out, but the belt is wrapped around it and should be removed prior to taking the drum out. Note the routing around the motor and idler pulley. Taking a digital picture of the belt routing will help with reassembly. once the drum is out, you will see the "rear bulkhead". at the bottom, in the 5 o'clock and 7 o'clock position are your noise makers, the drum rollers. Replace these and reassemble in reverse order and you should be good to go. While you are in the disassembled dryer, putting a little silicone grease on the idler pulley shaft will help it last longer, and vacuuming the inside will help too. Hope this helps!!
Dec 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Were is the water tank for the wipers
hi from uk if you open hood then lift the vented flap on the nearside/uk models or offside on l/h drive ? on top of bulkhead just below w/screen you will see the washer container it serves both front and rear washer jets also under the opposite flap should be the vehicle scissor jack and wheel brace ? hope this helps ?
Oct 02, 2009 | 1986 Renault Sport
No brake fluid going to right back brake
if you have brake pressure to the other back wheel it could be a clogged line or hose. Some "split" systems route pressure separately to one front wheel and the opposite back wheel in two "circuits" so be sure to check the opposite front (left) wheel for pressure as well. if this is the case your master cylinder needs work. Hope this helps
Mar 19, 2009 | 1999 Pontiac Montana
Blower Wheel has something stuck
TURN OFF THE POWER. youll need a 5/16 socket or a nut driver. remove the bottom access panel 2 screws across the bottom, then 2 more screws directly behind the a panel will release the front door panel assy. write down the light switch wire order, youll need to disconnect them.and put panel aside, youll then have to remove the next 4 5/16 screws holding the front bulkhead on, after rremoving the screws the panel lifts of the 2 lower tabs put aside, and youll see the sock and the fan motor right there.when reassembling you need to insert the front glides on the last bulkhead removed UNDER the drum assy and then insert the tabs into the slots and resecure(this bulkhead supports the drum with the nylon glides(very important!!!!!!) and reassemble the same way it came apart!!!!
Mar 24, 2008 | Amana DLE330RAW Electric Dryer
Traxxas Rc Revo Nitro Monster Truck Logo
55 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
paul tooker
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
