Question about Bass Pro Boating
Having problem motor fires but wont start think its the points how do i set them?
  • 487 Answers
Hi, has the engine been sitting around for a long time? I would check plugs first, and fuel; check fuel is flowing properly and if it is old, replace with fresh.
Sorry its not the answere to your question, but if the points were off it would start but run ruff!
Posted on Jul 21, 2010
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Jun 02, 2012 | Suzuki DR 750 S Motorcycles
54 Chevy 235 runns but no power and overheats.Should I have pointed rotor toward spark plug not distributor cap #1.My e-mail is jmincey23@sbcglobal.net
timing is way to slow. are points gap set properly. I think they are set at .016 for used points.
Fireing order is 1-5-3-6-2-4
with timing mark set at top dead center .i think it is a ball on back of engine. distributer rotor should be at #! .
Aug 18, 2011 | Chevrolet Chevy Cars & Trucks
Changed the plugs wires and cap and rotor...think I might have screwed the firing order up....no misfire just wont turn over.
the wires to the plugs should not keep the motor from cranking over. If the battery is fully charged the ignition switch should engage the starter. If you think the firing order is wrong you need to determine 1 where is top dead center (the position the motor is in when #1 cylinder is at the top of the compression stroke). 2 what direction does the rotor turn 3 what is the firing order One way to make it easy to rotate the motor is to remove the spark plugs. no compression means no resistance to the starter so the motor should turn over with the key in the start position. If it won't crank over with the plugs out then something is wrong with the starter, battery, starter relay, or ignition switch. I always start with the basics. the battery should have at least 12.5 volts. if it does check the battery terminals. even if the starter is weak you should hear a click when the key is turned to the start position. Once you get the starter to turn over the motor you can tell when the number one cylinder is at top dead center by putting a finger over the spark hole as you crank over. You will feel the compression as the cylinder comes up on the compression stroke. I have used a large socket to slowly turn the motor over and when you are near top dead center you should be able to see the degrees of advance on the timing mark. Set the motor at top dead center then see where the rotor lines up with the wires on the distributor cap. that is where number one cylinder should fire. You then follow around in the direction that the rotor turns and the wires will corispond with the firing order. I always make a mark on the number one spot on the cap with a felt pen. That way you have a fixed reference point. Take care to verify that all the wires are to the proper plugs before trying to start. Take extra care at this point and make sure your firing order and rotor rotation are correct. I would triple check this. The firing order and rotor direction are usually somewhere on the autozone repair web site
Apr 19, 2011 | Jeep Cherokee Cars & Trucks
I want to set my points on my yamaha xs250 twin do i set my left hand points then four cycles and set the right hand side
Your points will fire on the combustion and the exhaust stroke. Motorcycles use a wasted spark set up. The points will fire every time the piston approaches top dead center. Set the plate point set first(If there is a point set that you have to turn the mount plate to set). The plate set also times the motor. Then gap the second set.
Aug 27, 2010 | Yamaha XS2 Motorcycles
Lawnmower wont start
If this unit is very old, it probably does have points. But most are electronic. However, even if it does have points, the points is not the problem here. If the points can fire the primer and run until it dies, then i suspect you have a carb problem. If it lacks either compression, spark or gas you'll certainly will have an issue. I don't think you have a compression or a spark problem. Like i said, if it fires up to burn the priming then again i'd suspect the carburetor. Sounds like the center jet in the center leg of the carburetor internally may have a little dirt or such in it.
Hope this helps.
Good luck
Aug 23, 2009 | Garden
Not starting when warm
when u turn the ignition on before firing the starter do you hear a humm? if not maybe petrol pump or auto choke playing up, check ur fuses, under the bonnet2
May 29, 2009 | 1991 Peugeot 405
After the bike gets hot it cuts back really bad.
although you have had the carbs sync,i dont think the mixture settings are correct,the carbs are leaning out to much when the motor is hot
May 21, 2009 | 1997 kawasaki ZX-7R
Need the spark plug cable order for2000honda accord lx 4cylinder
The firing order is; 1-3-4-2 and the rotor moves in a counterclockwise direction. Turn the crank shaft and set the engine at TDC (top dead centre). This ill set the rotor arm pointing at No1 cylinder. From this point you can replace the HT leads in the above order.
Nov 23, 2008 | 2000 Honda Accord
1994 mazda miata mx-5 no start sounds like it is out of time
Make sure timing marks are both pointing to 12 o'clock then set distributor on #1,,, I think firing order is 1342 , its been awhile.
Jul 29, 2008 | 1994 Mazda MX-5
Boating Logo
46 people viewed this question
Top Bass Pro Boating Experts
ray gallant
obsteiner
Gordon Richard...
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
