Televison & Video Logo
Posted on Jul 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sanyo universal remote and toshiba tv. Used the code 114 lite blinked 5 times but it still won't work the tv. I even changed the batteries in the remote. The remote number is rmt-u110,
Anonymous
Level 3:
  • Master 524 Answers
  • Posted on Jul 21, 2010
Anonymous
Master
Level 3:
Answers
524
Questions
0
Helped
175114
Points
1756
Hi
Sometimes code wil not be accepted.
Please try same procedure with these codes
120
121
130
131
Thanx
2answers
Why is the remote not controlling tv?
simply point remote to the camera on your phone you should see a blink from remote if you see it it could be the ir on the tv if not get your remote serviced at your local repair shop
2answers
Universal remote I need the code to a Sharp TV
Hello
Three digit universal remote code for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four difit universal remote code for Sharp tv are:-
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV with its front panel power ON/OFF switch each time before trying an other code.
105helpful
7answers
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
16helpful
4answers
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
2helpful
Sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
2answers
I lost my orignal remote for my sanyo tv. how do i change the imput sourse with out it?
I am sorry but you cannot. maybe you can borrow one from a neighbor or a friend.
213helpful
15answers
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
3answers
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
