Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Washer won't operate
My G.E. Harmony washer displays "a problem has been detected with this unit" on the screen and it makes a beeping noise until I try to push a button on the washer. I have unplugged it from the wall and inspected the inside of the washer but I don't see any obvious problem. I manually rotated the tub and it turns fine. What could possibly be the problem and how can I fix it? Thanks!
catriver
  • 878 Answers
SOURCE: Notice! A problem has been detected with this unit
Troy, see if you can get it into a factory test mode. Start by pushing the power button on; next push the home button, next push the help pad, next push the start/stop and help pad together for 3 seconds, push the test load, the contrast screen should display. Now you can cycle through the different tests or let it cycle through on it's own, each test should time out after 5 minutes. This test will include the main board operation. If any tests fail, a failure code will appear. To exit the test, press stop/start to scroll down the screen list until the screen darkens. In case this model number is not exactly correct you should be able to find a tech sheet under the consol to guide you through these test proceedures. We need an error code to find the real problem, almost sounds like a pressure switch problem. Catriver..post back.
Posted on Aug 25, 2006
  • 641 Answers
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Posted on Aug 16, 2007
SOURCE: notice a problem has detected with this unit
If the home screen is not displayed press home then help. Then press my cycles and back together for 3 seconds.  Read what its says and then turn the power off then back on. It should be ready to go!
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: A problem has been detected with this unit
As someone else has mentioned elsewhere, if you hold the 'my cycles' and 'back' buttons for about 3 seconds or so, it gives you more information on the diagnostics. Write down what it says if you want, because it erases the errors after it shows them to you. Press 'more' when you can, and when you've seen it all, press 'exit'. At that point, it may or may not go back to the usual start screen.
If it does _not_ go back to the start screen, I can frequently just hit the power button to turn it off, then turn it on again, and it's ready to wash.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: GE Harmony washer will not move from problem notification screen.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and allow you to see any stored errors.
Posted on Apr 20, 2009
It beeps and rotates a blinking "H" and an "F" in
No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stuck on "problem detected" screen
Hi deejay961...You may want to begin with the following procedures. Please update your post with your results, and if needed, we can progress until we correct your issue....good luck my friend...chris The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature. "A problem has been detected with this unit" will be displayed on the screen. The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control. Solution: 1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT. 2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in. 3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 23, 2007 | GE WPGT9360EPL Top Load Washer
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
My washer is beeping and flashing the letter F
It means no water detected entering machine or Pressure switch trip not detected.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
3. Verify inlet valve operation.
1. Verify Drain pump operation.
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
3. Verify there is not a siphon problem.
4. verify wire harness connections to Inlet Valves,Pressure Switch,Drain Pump,Flow Meter and
Central Control Unit (CCU).
5. Check all hoses for possible leaks.
6. Verify pressure switch operation.
7. Verify flow meter operation.
Apr 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE Profile WPGT9150 will not start cycle
You have a bad transmition.
Please rate this solution
Aug 20, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Wont run
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Hf flashing on screen and beeping loud
H/F error is due to :-- No water detected entering machine or Pressure switch trip not detected.
Or
TO RESOLVE THE PROBLEM :
Press PAUSE/CANCEL twice to clear the display. globul1a.gif If there is no water in the unit:
globul1a.gif If there is water in the unit:
globul1a.gif Verify there is not a siphon problem globul1a.gif Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) globul1a.gif Check all hoses for possible leaks globul1a.gif Verify pressure switch operation
globul1a.gif Verify flow meter operation globul1a.gif Verify CCU operation
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not complete cycle
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Verify CCU operation.
good luck......
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Hf error code
Or
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Verify CCU operation.hope this helps pls do let me know
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
41 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
