Question about Tappan TGF320 Gas Kitchen Range
Oven heating problem
Oven heats too slow
oven will not ignite
  • Tappan Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 22, 2010
Oven pilot light slow to ignite, oven slow to heat up once the pilot ignites
the oven ignitor is weak and needs to be replaced
Gene
Jul 31, 2011 | Kitchen Ranges
Kenmore Elite Electric Rnage 2 years old model 790.9662. If you set oven to 350...never gets there or takes forever. I gave up after 35 minutes abd it was only at 235. HELP! PLEASE!
the gas valve on the back isnt on... the valve doesnt stop the stovetop from working, only the oven. You are seeing the ignition element heating up and thats slowing heating the oven.
Jan 11, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven slow to start heating (sometimes) not always. But once the gas burners ignite then the oven heats up quickly
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
May 11, 2010 | Jenn-Air JGS8750ADS Gas Kitchen Range
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Oven is slow to heat up to set temperature
heatman101
May 06, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
Top and bottom oven won't pre heat
I had the same problem and I replaced the igniter and had no problems since.
Apr 22, 2009 | Kitchen Ranges
Amana first addition oven (approx 10 years old) will not heat
I had a similar problem with my Amana oven, also about 12 years old. It was slow to heat and sometimes wouldn't reach the set oven temp. I replaced the oven igniter on a tip that it wasn't drawing enough current to open the gas valve solenoid. That did the trick. It starts immediately and heats to the right temp. Good luck. Joe
Dec 23, 2008 | Amana AGDS902 Gas Kitchen Range
Oven slow to heat
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Dec 14, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
221 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
