Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
I amn't able to drain eventhough i took the drainer out biut there are lots of water indside
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherI amn't able to drain eventhough i took the - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 21, 2010
How to drain water from 5.5kg twin tub
Get a rooter and clean the drainer hose...
Get electricity to the drain pump and make it work , only one control is broken on it , the drain pump is still good... find and replace the faulty switch , probably the one that stops machine when lid is lifted... that switch is 1st to go and so easy to Unscrew Unplug and replace...
Jan 07, 2018 | Washing Machines
I have a Whirlpool washing machine;model AWM5104.I wanted to know how you empty the drainer. I've heard that for some makes of machine,you turn it clockwise but mine doesn't budge!
exactly what do you mean by emptying the drainer?
If you are in the correct category of washing machines there is only a pump that pumps the water out into a drain pump or sink and the hose is higher than the tub edge
to fully drain the tub then simply place the drain hose at floor level or empty into a bucket or other low container.
make a new comment to clarify what it is that you want an answer for.
May 22, 2015 | Whirlpool Washing Machines
Draining for a Haier Window AC
no, this air conditioner is a manual drainer and is not made to drain itself
Jul 29, 2013 | Haier Heating & Cooling
Where do I locate the air condition water hose drainer? The a/c hose drainer is not draining any water at all, I do not see any water draining under the car, so, whenever I used the a/c, the cold water...
The drain hose does not actually exist. The evaporator box (also holds the heater core) is partially in the engine compartment and partially in the cab on the passenger side and excess water from running the AC drains immediately into a frame member. This is a unibody vehicle. There is no way to access the end of the drain tube to clean it out.
The drain hose runs through the firewall and into the frame There is no way to get to it from the outside of the vehicle. The only way to relly reach it, is to remove the housing.
Sounds absurd,but that's the frantic truth about this car..
Good luck.
Aug 10, 2010 | 1995 Jeep Grand Cherokee
Removal of insink drainer.
The drainer is very easy to remove...
Just use a screw driver or the jamm wrench to un hook the disposer from the drain by turning the ring that connects it to the drain.
Tehn loosen the three screws that hold the drain onto the sink bottom and take off the snap ring and the drain will pop right out...
Here is an exploded view of that...
http://www.plumbingsupply.com/insinkeratorpartsbadger5.html
heatman101
Apr 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Front louding not running . Whirlpool
You need to get inside and clean out pump assembly
Jan 14, 2010 | Whirlpool Washing Machines
Water will not drain out. still water in the bottom when it stops.
there could be a cloge in the draineg tube, look in to it, first try to pick out with some wire all of the food left over's from the machine it self (UNPLUGE THE MACHINE FROM THE ELECTRICITY) or use some comercial drainers like mr muscle or something like that
cheers
Oct 31, 2009 | Dishwashers
Avanty w789SA
its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Feb 26, 2009 | Avanti W789SA Top Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
103 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
