Question about Logitech Harmony 550 Remote Control
Loigitec Harmony 550 Remote does not respond to buttons pushed
I've been using this remote for a long time and have never had any problems until yesterday the remote just stopped responding. The remote still displays my activities but does not respond to any button I push. When plugged in to a computer you can change the remote's settings and update it with no problems but the buttons still won't do anything. Is there a way to do a hard reset?
The following steps will reset your remote. If this does not fix it, then it's probable a hjardware related problem.
1- Remove the battery from the Harmony remote, hold the 'Off' button and insert the battery back in. The screen will display 'Safe Mode'.
2- Make sure you have version 7.7.0 of the Harmony software installed on your computer. You can download it at http://logitech.com/myharmony.
3- Launch the software and log in to your account.
4- Click on 'Downloads' at the top of the screen.
5- Click 'Firmware' and follow the steps to update the firmware on the remote.
6- Update your remote.
Posted on Aug 03, 2010
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
Never had an issue until yesterday... When I turn the tv on,it immediately begins scrolling through all the channels and won't stop. It will not respond to the
I will assume you tried to unplug the set and plug it back in.
If you are using a sat or cable box connected to the cable fitting on the set try connection from the AV jacks to one of the video inputs on the set.
If set does it via the rear jacks it is likely the box and not the set.
Mar 15, 2012 | Samsung HL-T6187S Television
Just bought a used 27"
1. Turn on the TV or component.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
Aug 18, 2011 | ESA EF427E TV
Need to program my tv and dvd player to the remote
Please follow the steps below
Program the First Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3.Release the Setup button
4.Press the TV button.
5.Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7.If the device responds, you have successfully programmed your Philips universal remote.
8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To get the universal remote codes please visit below solution
http://www.fixya.com/support/t5395701-universal_remote_code_phillips
Thanx
Jul 27, 2010 | Philips Universal PH301S Remote Control
I need the codes for a brightstar br100z remote for a symphonic t
Hold the set up button until the red light stays on on the remote. Press power until the TV responds. My sleep timer displayed after 23 presses (hotel room Magnavox TV). Stop pressing remote. The red light will then flash a few times once you stop. Problem fixed.
Feb 01, 2009 | Universal Remote Control Remote Control
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
"AMP" button on Sony RM-VL 900T stopped responding
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Dec 27, 2008 | Sony RM-VL900 Remote Control
Progrm my universal remote
When doing the code search for this remote, and you get to the point where the tv shuts off, you press the reverse button BUT the directions should say KEEP on pressing the REVERSE button EVERY 2 SECONDS until the tv turns back on.  THEN PRESS STOP.  The directions I kept on getting were sayng to press it but they did not specify how many times.  YOU NEED TO KEEP PRESSING REVERSE UNTIL IT TURNS ON, THEN PRESS STOP.
I got these directions (after about an hour of searching sites I found) from www.rca.com
  1. f, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
  2. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  3. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  4. If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  5. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  6. To save the new code, press and release the STOP button.
  7. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
THIS HELPED ME I HOPE IT HELPS OTHERS WITH THE SAME PROBLEM.
Jul 08, 2008 | RCA RCR311B Remote Control
My Sharp Aquos TV has stopped responding to remote control(s)
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV.  Thanks for the tip!
May 14, 2008 | Televison & Video
Logitech Harmony 550 Remote Control Logo
1,520 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
