Question about RCA R52WM24 52" HDTV Projection Television
RCA Model Number R52WM24
Our tv went from being normal to crazy in the matter of a couple of minutes. It appears as if the picture is bowed. And you can see the words comcast 4 times on the screen all in different colors. We just got this tv in january of 07. Is there anything you can suggest?
  • 4 more comments
  • jimcsayo May 01, 2008
    Yes, I think it is convergence... BUT ... there is not "convergence" choice on the SET-UP menus... how do you reset the convergence on this TV???
  • mimibeth May 15, 2008
    what is wrong with these tv's??? I have just had the same thing happen today! I don't understand why you cannot access the convergence menu on it, when it does have an auto convergence choice (normally) on the menu options. Does anyone know the approx cost of getting something like this fixed??? Or am I better to get a new T.V.? I have really like my RCA, I have had it for almost 2 years and have not had any problems with it until now.
  • luhutt Aug 30, 2008
    Picture is bowed with 3 colors bleeding
  • rbrinza Sep 10, 2008
    how do you access the alignment convergance grid panel.what buttons do you hold together
  • debrakaypri Jan 16, 2009
    cannot access the convergence menu on it, when it does have an auto convergence choice (normally) on the menu options. Does anyone know how to help i called rca and they said i could unplug the tv for 60 seconds and that it would reset and it didnt work and they said to call a repair man
  • Anonymous Jan 22, 2009
    our tv hah colored lines acrossed the top colors are all mixed up and picture is concave
I GOT A PRICE FROM A RCA REPAIRMAN AS LOW AS 250 AND AS HIGH AS 400 BUCKS, MINE IS 18 MONTHS OLD NO HELP FROM RCA, I'M TRASHING MINE NO MORE RCA FOR ME.
Posted on Aug 20, 2008
    Scholar:
  • 76 Answers
Is this a projection set? If so you simply need to set the convergence. Otherwise I would try to return it to the retailer and exchange for different manufacturer.
Posted on Apr 22, 2008
On our rca hdtv model # R52WH77.. the tv is having like a 3d look on it and has a bow in the picture.. we bought the convergance repair kit from tvrepairworld.com and replaced the 2 parts it gives us.. ...
have you reset the convergence parameters after installing the kit to fix the option? Usually you will need to reset the defaults to get the outer edges back in alignment.
Aug 11, 2011 | RCA R52WM24 52" HDTV Projection Television
My screen to my RCA 56" HD TV is messed up. The picture seems to be bowed inward and the colors are all mixed up. I tried to do the convergence but it is not on the menu and I remember it being there...
t is the problem of convergence setting or convergence IC.
Comment by ready2helpu, posted on Oct 21, 2008 IF THE PROBLEM OF CONVERGENCE SETTINGS then check out this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
if the problem of convergence IC THEN check out this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
you can do it manually.
thanks.
Oct 21, 2008 | RCA R52WM24 52" HDTV Projection Television
My tv went from being normal to crazy in the matter of a couple of minutes. It appears as if the picture is bowed. And you can see the words comcast 4 times on the screen all in different colors.
Go to Menu then setup,If you do not see Convergence on the menu then problem is in the Deflection Board,Located on the bottom Left hand side.
Over on the Right hand side of the FBT flyback transfomer is 3 Fuses in a Roll FL231
they will be small rectrangler looking caps but are Fuses it will be the one in the Middle 0.06amps.
Mats Electronics 1-800-628-1118 you can take a pair of needle nose plyers and pull Top OFF of Fuses. You will also need to resolder all the pinns on the FBT.
Jul 06, 2011 | RCA R52WM24 52" HDTV Projection Television
I NEED TO KNOW WHICH KIND/ITEM# OF PROJECTOR LAMP FOR A RCA R52WM24
look for the model number on back of your tv then go on google and type brand and model and part you are looking for e.x Lamp
Feb 08, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Sep 29, 2009 | RCA R52WM24 52" HDTV Projection Television
The colors separate and the picture bows in the middle
Ur convergence is dead,buy convergence kit.U know how to solder?Tries these websites.Tv Repair World.com.
Sep 23, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca color problem
does the convergence option still appear in the on screen menu or has it disappeared? Let me know and I will assist you
May 28, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
RCA tvs have to be diagnosed by the Chassis number. Please repost the chassis number and I may be able to help you out.
Feb 09, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
200 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
