Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftman belt 1/2 hp garage opener with security sensor plus system. All remotes and homelink programed. Unable to get keypad to work. Enter code with light switch pressed then top bar pressed and nothing, go to learn light and enter code and enter, still nothing. I must be missing a step or need to combine steps. Any suggestions?????
    President:
  • 3,197 Answers
The simplest way to program the keypad is to press and immediately release the smart/learn button and then walk over to the keypad and key in your 4 digit code and press enter. If this doesn't work the keypad is bad or you have the wrong keypad. You don't say why you are programming everything so I am guessing about the wrong keypad part.
Posted on Jul 21, 2010
Why won't the keypad outside mount not open the garage door but the remotes work fine.
U will have to re program the keypad follow the directions on the lid of the keypad now on some models u have to hold down * # at the same time until it stops blinking then enter your 4 digit code press enter hold for 2 sec if opener does not release and press again as soon as u hear the opener click or light blink press 0 to store code then wait 60sec and try
Sep 02, 2014 | Chamberlain 1/2-HP Whisper Drive Belt...
I want to program my Genie ecellerator isd 1000 so that I can use my Homelink system in my car and my wife can continue to use her Genie remote that came with the opener. How can i do this? Thanks
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Aug 21, 2010 | Sears Genie Garage Door Gpwk12 Wireless...
Craftsman 1/2hp garage opener Homelink must be under unit to work
Have you tired reprogramming the remotes to the opener?
The opener receiver board may have failed, which happens. You can order a new one from Sears or other places on the Internet, and they are fairly easy to replace.
Once replaced, you will need to program the receiver to you remotes again.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can i program homelink with out a remote
The only way to program Homelink without a garage door opener remote is if you have a keypad that allows access to your garage. I tried EVERYTHING and then realized I had the keypad which is wireless; I simply unscrewed the battery operated keypad from its location and held it 1"-3" from the Homelink buttons in my car. I then punched in my code and held the enter button on the keypad at the same time as the Homelink button I wished to program. It worked flawlessly. Good Luck!!!!
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I CAN NOT PROGRAM MY BUILT IN CAR REMOTE ON MY NEW 139.53985DM
didnt try everything cause if you did, it would work! Get two people and garage door opener. One read manual from car under Garage door" or Homelink while other pushes button. When manual says if this did not work or if you have security plus or rolling code, continue with other instructions. You will need a working remote and will need to pushh learn button on motor logic board.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
139 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
