Question about GE GMR04HASCS Compact Top Freezer Refrigerator
I have a GE GMR04HASCS Compact Refrigerator.
I have a GE GMR04HASCS Compact Refrigerator. the fridge gets cool but the outside is really really hot to the touch. will this catch fire? I move it from my friends house to mine in my car on its side for about 25 min. I pulged it in and it stareted up fine but the sides are really hot to the touch. I am kinda scared. Whats up with that.
    Top Expert:
  • GE Master
  • 48,000 Answers
Refrigerators do not react well to being carted around in any position but upright.
Posted on Oct 29, 2017
catriver
  • 878 Answers
SOURCE: GE side by Side Fridge
froggy, First check the back panel of the freezer section and see if you have a big frost build up. If so, you probably have a defrost problem, heaters more than likely. If there is no frost build-up check to see if the fan in the freezer (evaporator fan) is running. If that's ok, next would be the automatic damper. Have someone unplug the refer. Open the refer door and listen for the damper door to open when someone plugs the refer back in. If thats operational, next would be the thermistors, you would have to ohm them out to see if they are in range. Seldom is this the problem. Check these things out and get back on what you find. Catriver..post back.
Posted on Apr 04, 2007
SOURCE: Freezer and Fridge side not cooling
check the condenser is not blocked with fluff, it is situated iether behind the lower front trim panel or in the back near the compressor depending on the exact model also ckeck the fan near the compressor in running freeley.
Posted on Sep 01, 2007
mikedurland
  • 481 Answers
SOURCE: Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Posted on Jul 10, 2008
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
What temperature should my GE profile fridge be set at so that my food does not freeze
depends on what type control you have . what is it set on now 6 then turn down to 3 or 4 .
Feb 27, 2015 | GE Profile Spacemaker Stainless Steel...
The top of my avanti mini refrigerator is hot
The return section of the gas cooling circuit is hot. Goes out cold comes back hot, so if that area has return lines behind it nothing wrong with the outside of a fridge being hot. Some fridges even have heaters built in around the doors and openings to prevent freezing up.
Jul 10, 2013 | Avanti 322Y Compact Refrigerator
Ge mini fridge seems to be overheating
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Aug 25, 2009 | Sanyo SR-4911M Compact Refrigerator
Plugged in refrigerator and it's getting really hot on side
I don't think fire is any issue. The unit cools itself by dissipating it's heat on its outside walls. For the moment, the outside is hotter than normal because the inside is also hotter than normal. Both will normalize after a while.
Jun 28, 2009 | Danby Compact Refrigerator DCR-101W
GE GMR04HASCS Problem staying cool
Your off/on thermostat control is sticking. Next time do not turn it off then on.
Take your hand a bump the control a couple times.
If it comes on, replace the thermostat.
Mar 11, 2009 | GE GMR04HASCS Compact Top Freezer...
Ineed to know the specs
The back reads like this: voltage-115 HZ60
I hope this helps.
Dec 18, 2008 | GE GMR04HASCS Compact Top Freezer...
Will not cool
If the compressor is getting really hot it's more than likely SHOT.
There is a small possibility you have a bad overload/start relay.
But compressors do not like getting hot.
Jan 06, 2008 | Haier HSB03 Compact Refrigerator
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Aug 31, 2007 | Avanti 310SST Compact Refrigerator
GE GMR04HASCS Compact Top Freezer Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
