Question about HP PSC 1510 All-In-One InkJet Printer
Hitrying to print invitaions 135mm x 270mm. Have them all set up on microsoft publisher but my printer(hp photosmart D7360) is teling me that the paper size is too small. How do I et printer to accept the cards?!!!
ctf1800
  • 4402 Answers
SOURCE: d7360
just use new ones.
Posted on Feb 21, 2008
SOURCE: Word Settings for Printing Postcards
I found the fix!! Once you have your size settings typed into your page layout screen and applied to the document, click print. Once you select your printer, click on properties (or printer preferences) click on the features tab (the tab next to printing shortcuts) and go to the resizing options section. click on paper size bar and scroll down to custom. once in the screen, give the shortcut a name you'll recognize, type in your dimensions in the provided spaces click save. once you go back to the features screen, scroll back down to custom and select your shortcut that you just created and apply it to both the paper type and paper size. click ok and go back and click ok to print! Hope this makes sense..if not, go to HP's website and type in your product name, type paper mismatch in the keyword search bar and click ont the first link in the found section. It will give you the same step by step instructions....
Posted on Jun 21, 2008
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
joecoolvette
  • 5660 Answers
SOURCE: How do you open HP Photosmart D7360 Printer case?
Hold the bottom base of the printer with one hand, grasp the top cover under the HP logo, and pull upward with the other hand.
Posted on Aug 12, 2009
SOURCE: HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Posted on Oct 13, 2009
Will the HP D7360 print page numbers at the bottom of the pages?
Yes , In the file you can add numbers wherever you want
Microsoft word or other writing software
Mar 23, 2013 | HP Photosmart D7360 All-In-One InkJet...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Printing is blobby rather than sharp
That my friend is your cartriges,i had the same problem.
Sep 28, 2009 | HP Photosmart D7360 All-In-One InkJet...
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart 8450 printer and Vista not compatible.
You will need to update your Microsoft Publisher program and you should just update the entire MS Office Suite to be compatiable with windows vista.
Jul 08, 2009 | HP Photosmart 8450 InkJet Printer
HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
Aug 03, 2008 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart D7360
try cleaning the cartridge contacts with alcohol and cotton swab.
Jan 16, 2008 | HP Photosmart D7360 All-In-One InkJet...
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP PSC 1510 All-In-One InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
