Question about Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 has a "printhead error". How do I fix this error?
    President:
  • 1,382 Answers
First thing to do is get the top off which can be easier said than done. The printer has four screws holding the top. After that remove the control panel by undoing the four screws holding it in place. This isn't strictly necessary but it makes life easier. Now move the print head to the left. To do this you have to lower a locking bar that is located at the base of the head. The head can be quite hard to move but it does slide left. Under the print heads you will find two pads of hard foam. These collect the ink when you perform a normal head clean and keep the print head moist. Soak these with water . Pool water on them and let it run through (it goes through to a large pad at the bottom of the machine by the way). Fold some tissue and lay it on the base when the heads pass over. Push the head back and forth over the tissue to clean the actual head. The tissue will come out covered in ink.Now for the tricky part get an old printer cartridge and remove the label on top that says "do not remove". Under the label you will find a couple of holes. Widen them / open them with a drill bit about 3 mm is good. Fill the cartridge with water and put it in the printer. Push the heads back over to the right as far as they will go. This will cause the sponges to come right up against the heads. Leave the set up over night. In the morning test the printer. Run a couple of head cleans with the cleaning cartridge in. Your problem is solved now
Thank you!
Posted on Jul 21, 2010
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
Sep 24, 2012 | Lexmark Optra S 1620/1625/1650/1855 Fuser...
I am getting a 922 service fuser error on my lexmark optra s 1855
922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
I have a printer error 935. Can you help me?
this is a printhead error and can be caused by the scanner or the engine board. scanner 60% engine board 40% to be sure you have all of the parts you need and be able to return the one you didnt use go to L-tech4u.com a simple email on the site and you get better prices support and instruction to do your repair
Aug 06, 2009 | Lexmark Optra S 1855 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Mar 03, 2009 | Lexmark Optra S 1855 Laser Printer
Optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Jan 03, 2009 | Lexmark Optra T610 Laser Printer
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
assembly. Check the continuity of
the mirror motor cable connected to
J3 on the engine board. If incorrect,
replace the cable. The voltage at
J3-7 measures approximately
+24 V dc. If incorrect, replace the
engine board. If correct, replace the
FRUs in the following order:
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
Lexmark Optra S 1855 Laser Printer Logo
531 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
