Question about SIM2 Televison & Video
Projector not working
I have a Sim2 projector. I have owned it for abut 3 years. Recently when turning the unit on it would start out with a high pitched whine until warming up then the lamp would come on and the picture would be fine. Now the unit turns on for about 1 minute then shuts down without the lamp ever coming on. Do I need a new lamp? Is there something else wrong? Not sure where to turn. There does not seem to be much in the way of customer support for the Sim2 brand. I have left voice mails to the Florida "customer service" office with no return calls. Any insight would be appreciated.
Bob
I have the same problem with a HT250, red power light on back of projector will not come on. But if you leave the projector plugged in and power switch on it will light after some time and the projector works as normal. Any suggestion please email lkrause0@fuse.net
Posted on Dec 06, 2008
My DLP projector SIM2 DOMINO D35 is turned on and works normally BUT picture is absent on all of inputs (projector shows NO SIGNAL, green indicators is ON). Sources of signal and cables are in order. What...
It is possible that the last time this was connected there must have been an higher input applied than is recommeded so that the input PRE_AMPS were loaded to fail.
You need to check with an signal trace on the input to find if an OP-AMP has failed or the LOGIC switching IC had failed.
Need to test using a signal tester and meter.
Jul 14, 2011 | SIM2 DOMINO D35 DLP Projector
We have a replacement bulb and I don't have a trap door to remove the old and install the new.
WARNING! Sim2 does does not recommend that you change the lamp, they recommend that you contact a local dealer for service. PROCEED WITH CAUTION!
If you still wish to proceed. This instruction is available at avsforum
http://www.avsforum.com/avs-vb/showthread.php?p=17983282
There are 2 recessed screws on the bottom near the front of the projector (really deep cavities). There are 2 on the backside of the unit. Remove all those and the top cover comes off. Inside you will see a fan held on by 3 screws (you will know it because there are 4 holes, but only 3 screws...that is normal). Remove those and take that fan module off. The lamp is then accessible.
Good luck! __________________
Jason C. Turk
Consultations, Installations and ISF Calibrations
585-671-2968
jason@avscience.com
Available for scheduled consultations...please contact the main office for details!
Mar 31, 2011 | SIM2 HT380 Grand Cinema DLP Projector...
How do you reset the lamp timer on a Sim2 Domino 60.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
Mar 16, 2011 | SIM2 DOMINO D80 DLP Projector
Power LED stays red - does not want to turn on
hi maybe I am very late for this, but do you still have the SIM2 D10?
I need some part if of course you have it and it still broken.
Thank you for your reply
Jan 20, 2010 | SIM2 Domino D10 Home Theater Projector...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Jul 15, 2009 | Office Equipment & Supplies
Trying to update Firmware on a Sim2 HT300
Take it to an Authorised SIM2 service agent . Some things are just not for the DIY
Dec 19, 2008 | SIM2 HT300 Multimedia Projector
Replacing the lamp in SIM2 ht-200
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
May 28, 2008 | SIM2 HT300 Multimedia Projector
Sim2 domino 20
Hi there
I checked the manual of your Sim2 , but they don't even mention the lamp in there.
You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
Televison & Video Logo
234 people viewed this question
Top SIM2 Televison & Video Experts
Are you a SIM2 Televison and Video Expert? Answer questions, earn points and help others
