Question about Maytag MER7662W Electric Range
The oven does not maintain the heat displayed. If I put cupcakes into the oven, or rolls, to bake at 350degrees, they are still not done after an hour and a half. The temperature displayed is what I have set, but not the actual oven temperature. When I called Maytag for help, they kindly sent a nice gentleman from A and E Factory Services on Monday, July 20th. He was unable to find the root of the problem and suggested I call back if the problems continued. That night it took an hour and a half to preheat the oven to 425
    Novelist:
  • 112 Answers
This sound like you have a faulty thermostat module. The digital temperature display is giving you a false reading. Your best bet is to purchse an in oven thermometer that will give you a more exact reading until the thermostat is replaced. Good luck and happy cooking.
Posted on Jul 21, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Oven will not maintain heat
possible thermostat problem in the switch
call the technician or get the part from tyhe servide agent spares
Feb 28, 2018 | Whirlpool Ovens
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
I lost the instructions on how to bake my Lil' Cupcake 1st Birthday Signature Plate from Celebrate Express. All the signatures are there, I just need to know what temperature to set the oven and how to...
I found the answer for this (I was looking too and saw your post) today on the company site that made the plate. it was in the FAQ section - but choose the link under the question about using the paint pen. Here's what it said:
Once paint is dry, it is smudge proof to the touch and safe for travel, but it is not yet permanent.
To make permanent, once your personalization is complete, allow paint to dry for 24 hours.
After 24 hours, place the item in a room temperature oven and then heat oven to 300 degrees, so that the item heats slowly along with the oven.
Once oven reaches 300 degrees, bake item for 35 minutes and then turn oven off.
Allow item to cool to room temperature inside the oven, at which time it may be removed.
Paint is now permanent, food and dishwasher safe!
Hope this helps!
Jun 12, 2011 | Celebrate Express Lil Cupcake 1st Birthday...
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
My baked goods are not turning out right. What is
Have you changed altitudes? Have you checked the actual oven temp with a regular oven thermometer?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
I have to cook way longer than recipe says.
This is usually caused by a weak oven ignitor. As they age, they seem to perform less effectively. Sometimes the oven will take several minutes to ignite the first time, and even worse on subsequent ignition cycles, resulting in overall low oven temp and poor baking. Replace the oven ignitor. Note, if you have a self clean gas oven, the ignitors are usually the same part number for the bake and broil, so you can try moving the broil ignitor (which is generally used much less than the bake ignitor) to the bake burner if you want to test it out before buying a replacement ignitor.
Nov 28, 2008 | Kenmore Ovens
Oven
sounds like a bad ignitor, sometimes lighting and not relighting during extended cooking time. dies it take longer than a minute to ignite gas? more then 10 in to preheat? smell gas while cookin?? all signs of a bad bake ignitor
Mar 08, 2008 | Magic Chef CGR1110 Gas Kitchen Range
Maytag MER7662W Electric Range Logo
145 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
