Question about Timex 27191 Wristwatch
Unable to locate original replacement band - nylon
Have been unable to locate original replacement band - nylon cloth, green w blue stripes on margins for CR2016 Expidetion Indiglo.
  • 831 Answers
The only place you can find an original band is through the actual vendor. Try this.:
TG Service Center
Returns Department
1302 Pike Avenue
North Little Rock, AR 72114 Phone: 800-448-4639
Email:custserv@timex.com Your only hope to find a band is if someone is selling like watch on Ebay, craigs list, etc and it is in new condition. Hope this helps.
Posted on Jul 21, 2010
What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
you will need to send the watch off to Timex csd@timex.com
May 09, 2017 | Timex Watches
WR means 'water resistant' to '30 meters'....http://www.timex.com/browse/men/watches/replacement-watch-straps/
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do I change batteries on a M.Z. Berger AW 213 watch
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Apr 28, 2014 | Bulova Watch
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
My timex indiglo watch's expansion band is too large. How can I remove links to make it smaller.
mcdevito75 here, Removeing the tiny pins to remove links is fairly easy, replaceing them is the hard part, for this you"d need a Link remover tool, Best Bet is to look for a small watch repair shop in your area, the $10--15.00 cost will equal your Time, effort and tool you"d need. Don"t forget to hold onto the links removed from the band in case you need them again.
Feb 09, 2011 | Timex Indiglo Expansion Watch
I have a Timex Indiglo watch that I had replaced the battery. I used the correct battery CR2016 and the watch doesn't work. I have replaced batteries in watches many times and always have had the watch...
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
Sep 15, 2009 | Timex Watches
I'm looking for a watch strap for a ladie's Timex expedition Adventure Tech watch. Where do I find one??
Timex stores are the only place I have been able to find their straps consistently. If you have a standard lug set up you might be able to get a similar after market strap at your local repair shop.
For Timex locations visit their web site...
Timex.Com
Sep 12, 2009 | Timex Expedition Adventure Tech Compass...
Timex 27191 Wristwatch Logo
183 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Geoff
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
