Question about Intel Desktop Board D845WN Motherboard
No Display on Mother Board
My Ram is OK.
Monitor is Ok.
Cmos bettery is Ok But No Display in Mother Board
    President:
  • 739 Answers
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Posted on Jul 21, 2010
  • 75 Answers
If you have another monitor,please hook up another monitor and check if the problem is with monitor or something else
If you have an external video card,you can try to replace that first
if these two thing did not work out then
i thnk your moherboard is faulty,you should change your motherboard and it will be fine
Mother board problem@ monitor & ram is ok but no display in monitor
check whether the cable is write if it is ok then press del key while the system is booting
Jul 31, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Toshiba tecra me will not post.
First of all thanks for posting giving me to change to solve your problem. Dear sir, First of check the RAM as well as CMOS battery. and did you linten the bee tone while u start your computer? Just unplug the ram and CMOS batter from mother board and replug it. i hope it will ok fine. ok byee take care.
Jul 11, 2009 | Toshiba (K000823110) Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Motherboards is running but no display..
mother board have a problem,if warranty is still now u sent mother board service center,my friend is same problem,he send mother board and now it is ok.
Mar 31, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
I NEED FOR 865GVBMSR2
Display probelum my mother board no is desktop board 845gvsr
My ram cmos battrery allredy ok so please give me solution.
Thanks
Have a nice day
Mar 16, 2009 | Intel D845GVSR Motherboard
Monitor
hi''
when u pc start check ram beep.
after rthat check your key bord numlock key if your num lock is on and off your cpu is ok and your monitor haas pro.
other wise check your ram clear it and fix exactly in its position.check your processor refix it . clear your bios setup take away your cmos cell for 15 minutes then fix it.also try cmos jumper to reset it
Mar 22, 2008 | Mercury P4VM800M7 Motherboard
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD and no display is comming
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD I cant see any display on my screen when i turn on my computer. But it looks it has read all the information from harddisk and loaded the operating system. but on screen i cant see any raster i.e. display.
First At this time u observe one thing check the Numlock Status if it is ON/OFF (Glow ) in Keyboard when u pressing the  Numlock key, the system is giving display check with pci vga card.
If not u  remove the Ram module and heard the Beepsound,if Beep is comming Clean the Ram & Ram slot the try it again
If not check with another Ram module.
If it is also not problem u clear the CMOS once and check it
Jan 22, 2008 | Computers & Internet
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Desktop Board D845WN Motherboard Logo
188 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
