Question about Bosch Integra® 500 SHX55M05UC Built-in Dishwasher
SHX55M dishwasher completes cycle but leaving all
Bosch SHX55M dishwasher completes cycle but leaving all food debris on the bottom basin and not filtering. what do i check first?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
DU940gwdg3 dishwasher does not wash well. Top, bottom and silverware come out dirty
Is the heating water element getting hot? Is the filter screen in the bottom of the basin clear of food debris? Do you pre-rinse the items being washed?
Apr 21, 2017 | Dishwashers
Dishwasher not draining
Check the lower basin filter for debris. Most of them unscrew to gain access to the impellers that grind food particles. That's the drain area but by removing the filter and cleaning it, you may succeed..
Jan 19, 2015 | Bosch Dishwashers
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
Dishwasher smells
johnnette acree, here are a couple possibilities
1. Look in the bottom of the dishwasher there is a catch basin or cylinder look for large food item that maybe stuck. clean it out.2. Be sure the drain hose is connected with a loop in it that goes up to the top of the cabinet and then back down.3. Run the dish washer empty with soap and heat dry or use sanitize cycle. after cycle completes leave dishwasher open overnight. The smell should be gone in the morning.
Hope this helps
Joe ConnollySealstonetops@gmail.com
Nov 16, 2011 | Frigidaire Dishwashers
Ok-when the dishwasher is finished with its cycle and I open it to empty it, the top rack is still dirty and there is dishwasher residue and leftover food particals on the door and the bottom of the...
Open up the filter and clean the filter out but also check the filter well.
Our bosch DW has a 2nd filter inside that.
Also check the filter is not broken.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Bosch SHV46C03 Built-in Dishwasher
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
I think my Bosch dishwasher might be a "lemon". I
Don't be afraid now, but , what I'n going to tell you works VERY often. Pour two cups of bleach into the washer and let it run a potscrubber cycle. They do this all the time at restaraunts, yes really! Let me know how this turns out. P.S. leave the machine empty when you run it. Thanks, Dana
Aug 22, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My Bosch Dishwasher doesn't clean
Let me start by saying your dishwasher only need the jet dry to be filled completely.let me tell you a trick because im a old bosch tech. fill unit wait 5 second add more rinse aid then almost close the door three times .up then down up then down.3times you will be able to add more jet dry because of dispenser can hold alot. once the air is gone then it is filled completely. this with turning the water on first b4 starting machine will help water temp.last add cascade dishwashing soap this will solve your problem.let me know how it went.
Aug 22, 2008 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
open the door while in the wash cycle and check water is spraying from the spray arms and that the spray arms are rotating. get back to me with the results and i'll try to give some guidance
May 04, 2007 | Bosch 24 in. SGI43E05GB Built-in...
Bosch Integra® 500 SHX55M05UC Built-in Dishwasher Logo
131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
