I have a 2 year old westing house washing machine and today it started making a loud thump thump thump noise so i removed the tub to see if there was something rubbing the inside but nothing it will spin still but it soulds like it is off balence even when empty
  • 487 Answers
Check the bearing.
Posted on Apr 22, 2008
My Kenmore 3.6 cu. ft. High-Efficiency Top-Load Washer is making a very loud thumping noice what can it be and how can i fix it
The flexible joint under the tub needs to be replaced. This will require disassembly of the cabinet to access the joint
Jan 17, 2013 | Kenmore 24032\24036 Top Load Washer
I have Whirlpool Washer model # WTW5510VQ0, it's 2.5 months old. The machine is balanced properly, and the loads are balanced, and the machine is properly leveled on the floor. When the spin cycle stops,...
Usually, washing machine comes with fixing bolts in the back (for transport only). Check it out if were removed before operating. Usually, there are 3 or 4 of them, with some coloured plastic washers. In the instruction manual also is a note about them.
Sep 11, 2017 | Whirlpool WTW5500X Washer
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer makes loud, thumping noises during spin cycle.
support bracket that supports the tub is breaking. stick your hand inside and push up and down and see if its coming apart. if u look at it when it runs does it wobble?(the tub) if not take a look at the pulley on the back and see if its wobbly.
Jun 22, 2009 | Washing Machines
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
