Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv plugged into a surge protector too.
  • Dennis Barnes Jul 21, 2010
    budmrtn
    The exact problem was the outside surge protector, I saw that the power light and the surge light was on. The surge protector went into surge mode and I have to replace it. I am unable to reset the surge protector.
    I plugged the tv into a working outlet and the tv just powered back on. Thank you again for your help and quick response.
  • 11,361 Answers
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 21, 2010
Testimonial: "Fantastic Results, very knowledgeable I can't thank you enough for your quick response!"
  • Bud Martin
    Bud Martin Jul 21, 2010
    That is good news that the surge protector did do its job by sacrified itself to protect the TV, you have the good surge protector that actually disconnected the power source to the TV, most cheaply made surge protector outlet strip will take the surge the first time and sacrified the MOVs without disconnecting the outlet on the outlet strip, so if the second surge comes along you will no longer have the protection sicne the MOVs already blown by the first surge and the outlet on the outlet strip will still supply the power, make sure to get the same kind again.
Electric stove works, oven turns on briefly then shuts down
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
Apr 10, 2014 | Jenn-Air Kitchen Ranges
Ok we had a violent thunderstorm, and I didn't have a chance to turn the tv before the power went out multiple times. I tried turn the tv back on and it started to turn on. But then made a popping sound...
You need to look at the power supply module to see if you can locate blown components, you will more likely to need new power supply module, hopefully you will not have other boards that are damaged also but you will need to get the power supply working first to find out if it has any other hidden problems.
Aug 21, 2010 | Televison & Video
My area had a thunderstorm and our power went out now my emerson tv won't turn on. Can you help me.
Some times electrical storms contain EMP's - electro-mechanical pulses- which affect the TV permanently.
Take it to a TV technician or junk it and buy a new one.
Jul 22, 2010 | Emerson Televison & Video
TV will not power up. red LED blinking 5 times
I always found the problem to be either a combo of the x-sus printed circuit board and the y-sus printed circuit board. It is also very worth checking out your poer supply circuitry as well. Good Luck.
Aug 27, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Trying to turn the TV on, the green light comes on briefly and then goes to red. It takes many attempts to get the tv on.
This is a typical problem for several Akai/Ilo models that utilize the MLT169A Main Power Supply. Your choices are to Replace the power supply (about $100 shopjimmy.com) yourself. Repair the power supply If you are an electronics technician. Or for the "money is no object" wealthy, take it to a local repair shop and expect to pay in excess of $300. Just be aware that the problem will most likely return in the near future. I am on my 3rd PS in 2 years, 1 lasted only 61 days.
Aug 20, 2009 | Akai LCT3201AD 32 in. LCD Television
Power problem with an LG 50PC3D Plasma 50" TV
YOU PROBALY HAVE A BAD Y SUSTAIN BOARD OR POWER SUPPLY. POWER NEEDS TO BE DISCONNECTED FROM THE Y SUSTAIN AND THE VA & VS VOLTAGES CHECKED.
Jul 29, 2008 | LG 50PX4DR 50 in. Plasma TV
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Television shut off and will not come one
you have a deadset.open the back cover of your tv.look if the fuse is ok,check the regulator.
Nov 07, 2007 | Sharp 32F-630 32" TV
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
1,509 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
