PC DVI to HDMI Regza Connection
I am trying to configure my 52LX177 Regza to a ATI onboard HD3200 DVI output.
I have tried all types of user manual supported resolutions with no success. The PC input thru a VGA connection works great at 1024 x 768.
The DVI output works to display a 1280 x 720 display on a Dell LCD screen. So I know it is outputing a signal. After setting this up and switching the cables from the Dell to the Regza HDMI 2 or 3 input I get a no video signal message. When I return to the Dell LCD screen I see a window message that to use the DVI to HDMI connection I will need to use a separate audio source from the computer. This tells me the ATI software is seeing the connection to the Regza.
I have tried just about everthing I can think of and could really use some help from a expert.
Thanks
  • 2 more comments
  • fixmedom May 17, 2008
    I am having the exact same problem.
  • Anonymous Nov 16, 2008
    toshiba regza 42" and ati 2600 pro
  • mrsruskets Dec 14, 2008
    REGZA 52HL167 having same issue, only showing Unsupported Video Signal instead of No Video Signal.
  • Anonymous May 11, 2009
    We're seeing the same problem on our computer. The computer itself sees that the TV is attached but the TV shows a "NO Video Signal" error.
I'm getting the same problem with an ATI Radeon HD 2400 going to a Regza AV555D on HDMI 1. In order to get the picture back I have to call up the source menu and move down to HDMI 2 (without clicking OK, just hover) and wait for the screen to change. Then go back to HDMI 1 for a few seconds until it flickers and then press OK. A bit long winded and far from a solution but it's enough to sync it all back together again
Posted on Jun 13, 2009
I can not get 7.1 HDMI audio output on my Gateway GM5664 running Windows 7.
While DVI and HDMI offer compatible video lines, the DVI connection offers support for two analog audio channels only and cannot transport data packets required for digital audio. You will not get anything beyond 2.1 audio across the dongle.
If you have a HDMI connector on your graphics board and your external hardware, try to use a proper HDMI cable.
Mar 14, 2014 | Gateway GM5664 Desktop PC
I need the settings to put this flat screen on my computor LCM 20-v5 ser# W2005cmc063905801
Can you please provide us also the barnd and model of your video card because its important so we can provide you the correct settings....You can also try this connect this monitor to the DVI port on your video card output then restart the computer and if you have teh setup CD for this monitor just run it and let it configure the settings for you...
Hope that helps............
Oct 02, 2008 | Computers & Internet
Tip
How to Connect PC to HDMI TV Step 1 Turn your...
  1. Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card.
  2. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV.
  3. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals.
  4. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
  5. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
on May 24, 2010 | Computers & Internet
I just bought VTX ATi Radeon 5670 1GB GDDR 5 and i put it in my computer. I did everything..uninstaled old driver and instaled new drivers..But i cant get the picture on my monitor.
you may need to change some bios settings i don't know what type of BIos you have but the setting would read something like: initial display on boot...and the options would be onboard or pci make sue its pci
^but befor you try that try booting up your pc with the graphics card plugged in (if you haven't already tried)
Apr 01, 2011 | ASUS Video Card ATI RADEON HD 5670, (1 GB)...
HOW To Make MY TV WORK ON MY COMPUTER ?
Hi
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Oct 04, 2010 | Computers & Internet
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
Conecting to pc
there are 3 ways you can hook up your pc to this tv. VGA, 15 pin D-Sub PC Input and DVI convert to HDMI. when using the DVI convert to HDMI, you will also need to hook up an analog audio to get sound since DVI only put out video output.
Jun 16, 2009 | Toshiba REGZA 47HL167 TV
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
Connect to PC via hdmi-hdmi cabel (3m)& hdmi to DVI converter
Please provide the driver link to the ATI HDMI applications. its a known problem from ATI
Dec 24, 2008 | Toshiba 32WL55E 32 in. LCD Television
Televison & Video Logo
831 people viewed this question
Top Televison & Video Experts
