Question about Samsung SGH-a737 Cellular Phone
I am trying to change the greeting on my cell phone. When I call my cell phone wait for the prompts then press 3 to access the greeting function I get the "are you still there?" message. I've tried many times. What next?
    Genius:
  • 1,040 Answers
Go to "menu -> settings -> display settings -> greeting message"
Hope this has helped you... Please rate the answer... Thanks...
Posted on Jul 21, 2010
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 1 Repeat a Message
0 then 6 Answering System On
0 then 2 Play Incoming Messages
0 then 7 Memo Record/Stop*
0 then 3 Skip a Message
0 then 8 Greeting Message Record/Stop*
0 then 4 Delete a Message 0 then 9 Answering System Off
0 then 5 Stop Operation
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
Feb 28, 2011 | Uniden Cordless Phone EXAI985
How do I access the voice mail on my LG Neon 2 cell phone?
  • Press and hold the "1" key to call into your AT&T voice mail.
  • 2
    Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
  • 3
    Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
  • 4
    Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
  • 5
    Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
  • Read more: How Do I Set Up My LG Shine Voice Mail? ' eHow.com http://www.ehow.com/how_5984327_do-lg-shine-voice-mail_.html#ixzz15IGt4VZz
    Nov 14, 2010 | Cell Phones
    How to change voice message on i560
    1. Access Voicemail
    2. You will be prompted to press:
      1 To Listen to new messages, or
      2 To Record and send a message.
      You will not be prompted to set your Greeting at this point - press 3 to Access Phone Manager.
    3. Press 1 for Personal Options.
    4. Press 3 to Record a Personal Greeting.
    5. To record the Busy Greeting (when you are engaged) press 1 or to record the Standard Greeting (all other occasions) press 2.
      Your existing Greeting will be played to you.
    6. Follow prompts to record a new Greeting:
      To Start press 2
      To Stop press 2
      To Save press 5
      To Review press 6
      To Delete press 4
      To Exit press * until system says "Thank you for calling".
    Let me know if this will help
    Nov 30, 2009 | Motorola Mobility i560 Cellular Phone
    Setting up your voicemail
    I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
    Nov 15, 2009 | Lands Phones
    How do you change greeting on the prostar?
    press one of the ports for the voice mail (on the right of the handset)
    when prompted to enter your password enter **789#
    the prompt should say enter function
    enter 405# the greeting sgould start playing
    either press # to confirm or re record the greeting
    when finished recording the day and night (if required)greetings press # until the prompt says enter function
    enter 111#to exit programming
    Oct 09, 2009 | Samsung Prostar 816 Phone
    Set password for voicemail
    1.Turn your phone on and press and hold the "1" button on your keypad in normal standby mode.
    2.Enter your four digit passcode with your keypad and press *. If you do not yet have a passcode, you will be prompted to create one.
    3.Press "1" to listen to the options in English, or "2" to listen to them in Spanish.
    4.Press "1" to record your own voicemail greeting. Wait for the beep and speak your greeting into your phone. Press "1" again to confirm your greeting.
    5.Press the red "End" button on your keypad and your voice mail will be set up. Press "1" again or at any time to listen to your voicemail by entering in your passcode and following the prompts to navigate your different messages.
    Let us know if this helps ...
    Thanks
    Shiv.
    Aug 23, 2009 | Samsung Hue SCH-R500 Cell Phone Car...
    I have a panasonic Cordless phone and can't remember how to remote access it?
    Using the answering system
    remotely
    Dial your phone number from a touch
    tone phone.
    2 After the greeting message starts, enter
    your remote code (page 59).
    LThe unit plays back new messages.
    LAfter playing back new messages,
    the voice guidance starts.
    3 Follow the voice guidance as
    necessary.
    4 When finished, hang up.
    Note:
    LYou can ignore the voice guidance and
    control the unit using remote commands
    Voice guidance
    During remote operation, the unit’s voice
    guidance prompts you to press {1} to
    perform a specific operation, or press {2}
    to listen to more available operations.
    Operations are presented by voice
    guidance in the following order:
    – Play back all messages
    – Play back new messages
    – Record your message
    – Erase all messages
    – Record your greeting message
    Note:
    LIf you do not press any dial keys within
    10 seconds after a voice guidance
    prompt, the unit disconnects your call.
    LIf less than 3 minutes of recording time is
    available, the unit announces the
    remaining recording time after the last
    message is played back.
    Remote commands
    You can press dial keys to access certain
    answering system functions without
    waiting for the voice guidance to prompt
    you.
    Key Remote command
    {1} Repeat message (during
    playback)*1
    {2} Skip message (during
    playback)
    {4} Play new messages
    {5} Play all messages
    {7} Recording a greeting
    message
    You can download the full manual at
    http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
    Please make sure to rate this solution. Thanks.
    Jul 23, 2009 | Panasonic KX-TG5776S Cordless Phone
    Not able to access our main voicemail on Vodavi Starplus STS
    To access the System Administrator Mailbox:
    1. Dial into voice mail: From any phone on system dial 150
    2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
    The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
    3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
    How to program greetings
    1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
    2. Press [1] to access system greetings. The system will prompt you for the greeting number
    3. Enter the desired greeting number.
    For example:
    1 = Default Day greeting
    2 = Default Night greeting
    3 = Default Temporary greeting
    4. You will be prompted with the following three choices:
    Press [1] to Review.
    Press [2] to Record. You will be prompted to record the greeting
    When you finish recording, press [#] to save the recording.
    You can then
    Press [*] + [*] + [*] to exit the system completely
    Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
    Voicemail
    Call your cell phone number (from any phone) and press * key while your current message is playing.
    You will then be prompted to enter your password followed by the # key.
    From there you should press 3 to access your greeting.
    Press 2 to re-record your greeting.
    Hope that helps,
    Sep 09, 2008 | Samsung SCH-u340 Cellular Phone
    Samsung SGH-a737 Cellular Phone Logo
    57 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
