Question about Leica D-lux 3 Digital Camera
We have taken many indoor photos that came out fuzzy> What is the best mode (setting) with or without flash?? Proper technique?
    Genius:
  • 1,040 Answers
Best way is top set it on auto mode and keep cam steady while taking photo...
Other options are increase ISO, aperture and EV level bit increasing ISO will reduce quality of picture so try to set ISO till 400, And I will advised you to never go beyond 800...
Or increase the amount of light in the room...
Hope this has helped you,,, thanks...
Posted on Jul 21, 2010
Help, my camera seems to work ok , but if i take a photo outside and then look at the photo that i have taken it is all white , it works well indoors ??
One possibility that you have to check is the outdoor setting of your camera, it may have been set on a night mode that's why it's capturing too much light or it may be on an indoor mode that do not allow you to take outdoor pictures, just double check the setting or restore the default setting and it's best if you read the manual to help you set it up the way you desire.
Jul 08, 2011 | Olympus FE-210 Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
How do I take indoor pictures without a flash?
Jul 20, 2010 | Canon PowerShot A570 IS Digital Camera
Can't turn the flash on, it's set to "off" on default; and when i try to turn it on there is no "on" option in the flash menu, just "off"
check that you do not have the setting on burst as it will not be able to flash in this mode. when looking atthe screen about to take a photo, select menu, the first thingthat comes up is the mode, if it is in burst change in to normal and your camera should now have the option for flash or auto again :) good luck
Feb 23, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
What is the best setting for taking photos through glass.i have a olympus sp-590uz .ive only had the caamera a few days any help would be great
Photography through glass isn't difficult if you know a few guidelines.
If you're indoors in a museum, or aquarium etc, it would be best to turn the flash off. This will eliminate the flash reflecting into your photos.
If you need to use a flash, make sure you're not squared on the glass. IF you're at a direct, 90 degree angle from the glass, that's when the flash will reflect off the glass and back into your lens. An angle between 50-70 degrees will all the light from the flash to illuminate the subject on the opposiite side of the glass without reflecting.
You're camera has a high megapixel resolution so you can get great color and detail. If you use the zoom feature, you'll need to hold the camera very steady or if possible, use a tripod.
Another technique that alot of photographers use is called "bracketing" . Many of the newer digitals have a setting that will allow you to do this. Bracketing is simply taking 2 or more photos of the same image with slight exposure setting changes being the only difference between each shot. For example, one shot would be normal exposure, one would be a step or two over-exposed, and another would be a step or two under-exposed.
Many of the cameras will take the 3 shots all together-check your owner's manual for specifics.
With these simple techniques, you'll look like an ace!
K
Sep 18, 2009 | Cameras
Blurred images
Any number of things.
Low ISO. No Flash. No tripod. Too little light. No "shake" correction on the camera.
Depending on the goal of the photo, you may wish to use a tripod. Or use the flash. Or use a higher ISO (400+). Or any combination of these.
The easiest thing to do would be to make sure you use a flash. If you're trying to take a photo of something without the flash, you'll have to use a tripod. And even then, if something is moving fast through the frame, it'll likely be blurry. You simply need more light.
If you're new to digital cameras, I recommend the automatic settings. There's an "action" mode which usually has a man running as an icon. Or someone in motion. Some cameras even have settings for use at night or in darker rooms. Try those.
If you feel comfortable, you could manually bump the ISO up to 400 and try again. Your photo may be a little "grainer" and will probably look a bit ugly blown up much over a 5x7, but for 4x6 or anything online, it should be fine.
Feb 27, 2009 | Polaroid i830 Digital Camera
Canon Powershot SLR takes fuzzy photos
Guys,
you need additional flash or brighter light to click in low lighting condition. In order to compensate for low light conditions, the shutter goes slow and therefore you get fuzzy pictures.
Another way is to click on movie(video) mode and then atleast you can see them moving around as well as while editing, you could take out some pictures from the video( though on lmuch ower resolution).
Jan 28, 2009 | Canon PowerShot S5 IS Digital Camera
Fuzzy Images
There is insufficient light indoors, so the camera is selecting a slow shutter speed, which is causing camera shake, hence the 'fuzziness'.
Apr 02, 2017 | Nikon COOLPIX S7 Digital Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Technique on taking images of baseball cards
Greetings sandb27,
Your best route to avoid flash reflection on your cards is to find a lighting situation where you do not rely on flash. I would suggest a small handheld tripod to stabilize the camera and shooting without the flash. You might also try to use the Indoor Mode. Indoor Mode prevents camera shake blur and adjusts the white balance to preserve the subject's true color when working under tungsten or fluorescent lighting.
Thank You,
Agent Dort
Go Ahead. Use Us.
Mar 17, 2008 | Canon PowerShot A560 Digital Camera
Leica D-lux 3 Digital Camera Logo
65 people viewed this question
Top Leica Cameras Experts
Steven Wander
Steven Wander
Steve
xalint1
xalint1
Are you a Leica Camera Expert? Answer questions, earn points and help others
