Question about RTO 20 14" Abrasive Chop Saw Blades Metal Cut-off Wheels
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
    Problem Solver:
  • 11 Answers
Go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Posted on Dec 22, 2010
Can I use my metal chop saw to cut wood if I replace the blade with a wood saw blade?
Its conversely sometimes possible if you was asking about a wood saw with a steel saw blade but i cannot advice that in both application its not safe because not only of the difference of power but most it is the much higher RPM by diameter, just beware always on the max rpm you can read on your saw blades!!, it can give strange accidents with objects it can grab and swinging outbroken parts away.
Sep 28, 2016 | Makita "2414NB 14"" Chop Saw"
Saw starts runs good then when i start cutting it
Hi Jason:
Make and model might help but here's two ideas:
1) Remove muffler and clean it. They can get plugged up with carbon and the saw will run at low RPM but will quit because of excess back pressure when you try to rev it up.
2) Set the high and low speed carb settings. Start the saw then gradually increase engine speed until full throttle. Screw the hi-speed needle in slowly. If RPM immediately drops, back it out until Rpm increases, then starts to drop. Screw back in until peak rpm reached, then starts to drop. Back out to peak, then 1/3 turn more.
Set low speed so engine runs smoothly but chain does not turn.
Hope this helps.
Feb 01, 2016 | Garden
2000 merc 90hp elpto after running 15/20 mins at 5000 rpm it drops down to 3000 rpm and stays there ... any ideas ?
this could be the auto choke sticking till hot probably the air intake temp sensor
Jan 19, 2015 | Motorcycles
Voltage drop. When in parked I rev up the engine, when it comes down, the voltage drops from 14 to 10, for about 5 secs. I think the truck will cut off but it immediately comes back up to 14.
If the alternator is weak, and you have accessories like the headlights or blower motor running, and the RPM drops below 600, the voltage could be below 12. It would depend on the load, RPM, and several other factors.
Feb 12, 2014 | 2000 GMC Yukon XL
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
I have a 89 katana that cuts out at 5000 rpm
The power regulator may be at fault.
  1. GSX 600F Katana - Motorcycle Specs
    www.motorcyclespecs.co.za/model/.../suzuki_gsx600f_katana%2098.ht...Suzuki GSX 600F Katana ... Wet Weight, 229 kg / 504.8 lbs. Fuel Capacity. 20Litres ... The original GSX600F was launched in 1988 as a sportsbike. At that time ...
Dec 07, 2012 | 1989 Suzuki GSX 600 F (Katana)
What should the gear ratio be for a belt drive table saw?
you need max 5000 rpm for 10" blade
if you have a 1725rpm motor and 1.5" pulley on saw,with a pulley of 4" on motor the saw rotate at 4600 rpm if the motor is 3450 rpm 2" pulley give 4533 rpm
Nov 20, 2012 | Saws
Plastic safety key broke Black & Decker table saw cat# 1736
Try sears .They shoul be able to get it eor you
Mar 14, 2009 | Black & Decker Saws
RTO 20 14" Abrasive Chop Saw Blades Metal Cut-off Wheels Logo
120 people viewed this question
Top RTO Saws Experts
Putter71
Level 1 Expert
Jim Parker
Jim Parker
john h
Are you a RTO Saw Expert? Answer questions, earn points and help others
