Question about Kitchen Ranges
I had a fuse blow out in my home a week ago. Only my stove plus an overhead light and one outlet in the same room was out int hat room the kitchen. In the garage the garagre door light and one overhaad lght ewas out. In the bathroom one oberhead light was aout as well. the first replacemetn fuse blew out immediately. The second fuse lasted about 20 minutes. I called in an electrician. He suspected a crimped wire and once corrected the power was back on for a huor and then blew again. He then located tightened 2 loose wires on fuse box which were tightened and that seem ed tow for four days. now that same fuse had blown again. I hahve reoplced the fuse 4 times and cannot get it to work. the fuse in question that I replaced was a 20W amp fuse that I am told is no longer avaialbe. I am using a 20 amp tl fuse since I was told that is the replace for the 20W. is it possible that something not on the circuit that is blowing out is causing the problem? any suggestions to diagnose
  • Kitchen Ranges Master
  • 5,603 Answers
It sounds like you have a VERY unsafe condition and you need to find exact cause before you have a fire from it...
OFTEN there are hidden loads such as doorbell transformers... remove the fuse and see if doorbell ceases to work... if so, find the transformer.
Wiring within lamp holders would be suspect... the replacement fuses are blowing the short away temporarily and then it re-establishes itself and blows again.
Look for loads that may NOT be obvious... Furnace, AC, etc...
PLEASE pursue this aggressively as it is a very dangerous situation.
I would recommend NOT sleeping in the residence without removing the fuse during sleep time.
Posted on Jul 21, 2010
30 yer old caloric stove wher light pilot
http://www.partselect.com/Caloric-Stove-Parts.htm
Jan 04, 2014 | Kitchen Ranges
2010 Mazda 6, room fuse. A few weeks ago, my radio, interior dome lights and power locks all stopped working at the same time. Come to find out the fuse labeled "room" was blown. Replaced it and didn't...
I just had the same trouble in a 02 mazda millennia. found the SHORT.it was in the wiring of the drivers sun visor lights. no kidding, too simple. I hope yours is as easy to fix,,
Aug 22, 2013 | Mazda Cars & Trucks
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
No power , no clock, timer, no auto lighting in oven or stove burners, no lights nothing
Some stoves have secondary fuses inside the stove. Check these fuses.
Nov 19, 2011 | Kenmore Kitchen Ranges
A week ago our dehydrator worked fine and today it is blowing cold air as it used to blow hot air.. help
Hi, Check if it has fuse and /or replace. Use another plug in the room. If all is OK heater coil maybe burned out. Replace.
Jun 12, 2011 | Conair Waring Pro DHR20 Food Dehydrator
Keurig coffee maker causes kitchen electricity to short out.
I'm not completely certain what the problem is because it's not displaying your whole subject (it get's cut off after electricity to...). However, if it is solving the problem by moving it out of the kitchen, it's likely that the problem that the circuit is overloaded. Coffee makers have a large current draw, as do many other kitchen appliances. If you plug too many of them into the same circiut and then turn them on, you will put too high a drain on the circuit and it will cause the the current to become unreliable and then, eventually, through the braker or blow the fuse to protect the wiring in the wall (to keep it from catching fire). If this is the case, you need an electrician to run another circuit or remove some appliances from your kitchen.
Sep 18, 2009 | Keurig B100 Coffee Maker
The microwave stopped working
Ck your gfci breaker in your wash room or bath room. If this dosn't fix it it may be an internal fuse. If this is the case you will need to find what caused breaker to blow or it will happen again.
Aug 21, 2009 | Microwave Ovens
Whirlpool SF330PEWW5 Completely Dead
Open the backguard on the range to access the electronic control. If you read 120 volts into the control and nothing works,...replace the control.
May 24, 2009 | Whirlpool SF378LEP Gas Kitchen Range
Gas stove stopped working
Hi . I would begin by pulling the stove out and making sure it is plugged in. If it is, unplug it and plug something else into the plug like a blow dryer to make sure you have power to that outlet. If there is no power, you have either blown a fuse or kicked a circuit breaker. Go to your electrical panel to replace the fuse or reset the circuit breaker. good luck.
Feb 01, 2009 | Kenmore Kitchen Ranges
Modular Home Wiring Schematics
Won't be a wiring schematic for it. If it is a modular it will be wired same as a house. Unfortunaltly it will be wired by the lowest paid electrician you have ever seen. LOL. If the wires are hot, put a multimeter on them and have someone flip the breakers one by one to identify the wires and breakers. If they are not causing any problems then they are just spare connections. Don't know why they would even be there.
Dec 11, 2007 | Computers & Internet
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
