Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
Control lights are flashing, normal wash, rinse only and cancel...will not let me start dishwasher, will not let me choose heavy wash, shut off fuse, it reset and went on for about 30 seconds then canceled and starte lights flashing again...
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 02, 2012 | Kenmore Dishwashers
Dishwasher won't start - lights for Normal Wash and Cancel are flashing
check the controls,make sure that they are not stuck.
Dec 31, 2011 | Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
Clean light flashs seven times, stops and then does the same over again.
bellman, on this model I believe you can clear the fault by pressing high temp scrub--air dry--high temp scrub--air dry in that order. Your normal cycle on this dishwasher is approx 97 minutes without the thermal holds, (pauses to heat the water to proper temps.) So of course it's going to go over 97 minutes. This is for heavy soil. Light soil, approx 89 minutes. Some models have a soil sensor, some don't. If the sensor is out of specs..it could add to long wash times. The heater may in fact be the problem, he needs to check it. The heater runs through the nuetral side of the door switch so you want to make sure the switch is closing and the dishwasher is level and secure. He also wants to check out the resistance of the thermistor, should read 48 to 52K ohms at aprox. 75 degrees. Catriver..post back.
Apr 14, 2007 | Kenmore 24 in. 16692 Built-in Dishwasher
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
117 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
