Question about Microwave Ovens
I have a Delonghi Magnifica EAM3500 fully auto coffee machine that is having problems with milk frothing. There seems to be an internal blockage in the steam system as I can't even get water to come out the water spout. It has no problem making black coffee so the boiler is producing steam there just seems to be some sort of blockage stopping the steam getting to the milk jug or water spout. I can't even descale as it uses this same function. Any ideas?
    Genius:
  • 1,040 Answers
It seems that there is a blockage. So cleaning the milk compartment will solve your problem.. Download the manual from the given link. On page 17 the procedure for the cleaning milk compartment is given and also go through page no. 22 (especially last three rows)
http://www.retrevo.com/support/Delonghi-EAM3500-Coffee-Makers-manual/id/3878ci577/t/2/
Hope this has helped you... Thanks...
Posted on Jul 21, 2010
  • wdmurray Jul 21, 2010
    Thanks for your reply but you misunderstand my problem.
    The problem is I'm not getting steam, or for that matter even hot water, out of the hot water spout which connects to the same output as the milk jug. As I said I can't even descale it as this uses the same hot water function. The problem is an internal blockage in the machine itself. I've even tried pulling it apart to some degree and I'm not even getting water or steam to the solenoid that is behind where the jug attaches. It is building pressure as I can make coffee, and I can hear the pressure building when I try to run hot water or froth milk but then it just gives up and releases all of that built pressure into the drip tray.
    I have also tried a brand new milk jug which had no effect on the problem.
User manual required for DeLonghi Magnifica ESAM 4200.s
here is general technical data for the unit
http://www.delonghi.com/uk_en/products/esam-4200s/
and here is the manual!
http://www.filesavr.com/YE9UE5DM5WIBGUV
Hope I helped, thanks for using FixYa!
Aug 08, 2011 | Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
Hello, I have a Delonghi Espresso Machine (EC 155). I bought it 17 days ago and I have used it twice in a day carefully. Everything was perfect with my machine until 3 days ago. Then I observed these...
Your machine is new and its under warranty you have rights to replace it with new one. Call your dealer where you brought it, it's either they will replace it or send a service technician.
It will void the warranty if you try to unscrew something.
I hope my advice gives you an idea regarding your unit problem.
Mar 29, 2011 | Microwave Ovens
What does it mean by 1/3 expresso, 1/3 steam milk and 1/3 frothed milk? 1/3 cup...1/3 teaspoon??????? New to this. what are measurements
i'm sure it is referring to total volume, that being 1/3 of your total is expresso, 1/3 of total volume is steamed milk, etc etc. it is not really a measurement but a ratio of the different components of the drink you are making, example,,, chocolate milk might be 1/4 chocolate and 3/4 milk. if you were making it it would take 1/4 of the "mug" you ar using filled with chocolate, the rest or 3/4 filled with milk. make sense?
Jan 17, 2011 | Microwave Ovens
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
My DeLonghi Magnifica S ECAM23210 coffee machine is leaking water from the back.
I received the exact same machine for Christmas yesterday and had the exact same problem! I took it back to Williams Sonoma today and exchanged it for another one and I just started it up and have the SAME problem! Water comes out the bottom onto the counter - never even makes it up through the machine. This must be a batch of lemons - I guess I'll call Delonghi tomorrow.
Dec 25, 2010 | DeLonghi Microwave Ovens
Microwave Ovens Logo
172 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
