Question about Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1900 keeps paper jamming, and i don't know whats wrong
pineworks
  • 4041 Answers
SOURCE: my canon ip1900 says paper jam, gives 3 orange
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Testimonial: "you would not believe it was my 3 year old boys blue jelly octopus stuck in printer. many thanks"
  • 13433 Answers
SOURCE: my canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
Kuwagata
  • 181 Answers
SOURCE: canon iP1900 paper jam error
Use this Ip Tool,
Reset your printer.
First:Find the model on the tab, then reset the black and color,after that reset the platen and main, and finally reset the EEPROM.
Hope it works!!!
Posted on Oct 18, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
Danieldesmon
  • 56 Answers
SOURCE: my printer is Canon PIXMA iP1900. It has a paper
hai there...i think your printer have something stuck from inside....check your roller if anything stuck there....
Posted on Mar 01, 2010
Canon pixma ip1900 paper jam
Hi
Here's a few things you can try :-
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Also if your Canon printer has fax capabilities, and you are getting a false paper jam error, the problem is easy to fix.
Open the scanner lid.
You will see a white strip on the left, under the lid.
There are also two small, white tabs near this strip.
Gently pull on each tab. You should feel a small "click" on the tab that is jammed.
This fixes the problem.
I suspect that when previously scanning something like a book page, one of these tabs got pushed the wrong way.
Hope it will help.Also you can get back to me if you need further assistance.
Thankyou.
Dec 05, 2011 | Canon PIXMA Office Equipment & Supplies
Resetter of canon iP1900
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1900, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1900, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1900, iP1300 Printers should respond as normal
Jul 06, 2011 | Canon Office Equipment & Supplies
My cannon IP1900 printer cannot print, it says paper jam, orange light blinks. I need assistance
Dear Sir,
i am giving u step to solve your problem,
Step 1 Turn your printer off and on to see if it can take out some or all of the jam automatically. If not, turn off the printer and go to the next step.
Step 2 Inspect where the printed paper stops. If the stuck paper is visible and on its way out of the device, try to manually remove it. If you can not pull the rest out easily, then refer to the next steps.
Step 3 Remove any paper trays. Check if any wrinkled or damaged paper is still stuck in the printer. If so, remove any other appliances you can (toner or ink cartridge if necessary) and look for the paper shreds. Make sure nothing has been left in this device.
Step 4 Tidy your blank papers, turn the printer back on and try it again. If the paper jam massage still appears, repeat the above steps. If no paper stuck in your device but the error still persists, well then it’s likely your printer is experiencing another hardware issue: maybe the rollers or some other part need to be adjusted or replaced. Check the printer manual and the manufacturer’s website for directions, or contact your support line for additional assistance.
Things you should take care when manually removing paper
l You should be careful, especially for a laser printer – laser printers can get hot.
l Do not remove your jammed paper from where the blank paper enters the printer, or your device might be damaged easily.
l If you find a piece of jammed paper, pull it out with both your hands carefully so as to keep the paper from tearing. If several sheets of paper jammed together, try to loose the jam by pulling out the middle one first.
l If the paper does tear, you may need to manually rotate the gears that feed the paper through the printer to free the shreds. Don’t force anything.
Thanks For Your Time,
Apr 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I got an error with my canon ip1900 it says "paper jammed" i press Resume but nothings happen it's just repeating the error "paper jammed" what i need to do?
You need to open the printer and remove any piece of paper no matter how small. This can be causeed by even a small sliver of paper or even paper dust. It can also be the paper sensor but thats very uncommon.
Take the paper out fan and restack it. Then open up the printer and clean it as best you can. Put everything back in and close it up and you should be printing.
Mar 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1900 says paper jam, gives 3 orange flashes and 1 green flash .cant find any paper jam?
Hello there
Mar 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My printer is Canon PIXMA iP1900. It has a paper jam problem, I couldnot find any paper in it. I cannot use it now. Can you help
Feb 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1900 paper jam error
Use this Ip Tool,
Reset your printer.
Hope it works!!!
Oct 18, 2009 | Office Equipment & Supplies
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
My canon mp140 keep on flashing E and then 2 whats the problem
e2 is no paper, E3 is paper jam, E4 is no ink, E5, wrong ink, E8 waste ink absorber full
Jun 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
194 people viewed this question
old marine
old marine
