Question about KitchenAid KHMS155L Microwave Oven
No power to the microwave
My husband slammed the microwave door and then we lost all power. There is power to the outlet and cord. Do you know what the issue might be?
  • 975 Answers
Yes !! check the micro switches where the door latches , you have to open the microwave to check inside if switches are in their place or broken . hope it helps
Posted on Apr 22, 2008
Microwave power off, but will flicker when door shuts
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Mar 20, 2014 | Samsung SMH9151 Microwave Oven
Brada microwave
please make this test and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Dec 16, 2013 | Sanyo Microwave Ovens
The door of the combination oven microwave slammed shut and the oven lost all power
check the main cable of mven maybe its Rupture test it if it give 220v ac or 110 vac
if it ok then check fuse bass wich the cable connect on it maybe it damaged
Nov 27, 2013 | Bosch Microwave Ovens
Panasonic microwave will not power on
follow this steps and fix it. God bless you
Nov 27, 2013 | Panasonic Microwave Ovens
MICROWAVE FUSE BREAKDOWN
follow this test and fix it. God bless you
Nov 26, 2013 | Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Door slammed and no microwave is dead
yep you got it in one, I must have advised about 10 people today about this. when the door is slammed the door protection circuit does not operate correctly and then takes out the mains fuse inside the unit. renove the case and locate the fuse, normally where the cable enters the unit. as long as the fuse is the correct amperage, lenght and diameter you have no problems. do not test the unit with the cover off and be careful as the capacitors can hold a lethal charge
Feb 19, 2009 | LG LMV2053 Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
KitchenAid KHMS155L Microwave Oven Logo
104 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
