Question about Campbell Hausfeld Single Stage Air Compressor. Single Stage Cast Iron Compressortwin Cylinder Vt Pump with Flywheel
I AM TRYING TO FIND OUT THE OUTPUT OF AN OLD COMPRESSOR cAMPBELL hAUSFELD vt-5187
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
  • 8 Answers
SOURCE: Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Posted on Aug 07, 2009
  • 73 Answers
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
Posted on Oct 17, 2009
SOURCE: electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Posted on Apr 07, 2010
Testimonial: "thank you, this has had me stumped for days now. simply flipping the pressure switch off then back on again solved the problem. "
  • 3 Answers
SOURCE: Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Posted on Oct 31, 2010
What is the cylinder head torque requirements for a campbell hausfeld wl660700aj
The screws are either 1/4 inch or 5/16; I can't remember for sure - they may even be metric. But the torque is not really critical. Try 4 to 5 ft pounds.
Aug 17, 2016 | Campbell Hausfeld Air Tools & Compressors
Campbell hausfeld 60 gallon sight glass oil leak
Try here http://www.about-air-compressors.com/campbell-hausfeld-air-compressors.html
Jul 30, 2012 | Campbell Hausfeld Air Tools & Compressors
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld compressor has trouble starting
Sounds like your unloader valve is not releasing pressure in the line to the compressor. When it shuts off after filling up if you do not here the psssht that they make when it is releasing the air in the line to the pump. then the line is still full of pressure which makes it hard for the motor to start. Check your unloader valve.
Mar 30, 2009 | Campbell Hausfeld Single Stage Air...
Unloader valve leaks on my compressor leaks air constant and I think that it must need replacing, does it? just old or what?
THE VALVE COULD BE BAD BUT IT MORE LIKELY THE CHECK VALVE IN THE TANK ISNT CLOSING. DRAIN PRESSURE AND REMOVE CHECK VALVE FROM THE TANK AND INSPECT.
Mar 08, 2009 | Campbell Hausfeld Single Stage Air...
Compressor not wired, no schematic or instruction in manual
There is a schematic under the cover of the elecrtrical connection box. Remove the top of the box ( typically one nut on top of the pressure regulator) and look under the cover you removed.
Good Luck
Jan 14, 2009 | Campbell Hausfeld Single Stage Air...
Campbell Hausfeld Single Stage Air Compressor. Single Stage Cast Iron Compressortwin Cylinder Vt Pump with Flywheel Logo
76 people viewed this question
Top Campbell Hausfeld Plumbing Experts
Paul Carew
Tom Chichester
Are you a Campbell Hausfeld Plumbing Expert? Answer questions, earn points and help others
