Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Micro 8GB cruzer
Am running a Vista Home version.
1. Frequently, when I open a file on my USB and work on it , the computer does not allow me to save it to the USB.
2. From time to time, the file I am working on off my USB converts to a tmp file and then disappears from the USB. It show us under windows explorer as a rescued document ( txt file). How can I stop this and also convert the txt file back into the original Word document?
  • Raven926 Apr 22, 2008
    Mine also converts documents randomly to temporary files when I am saving then they randomly disappear! I am worried I am going to lose something important!
    Sniper:
  • 55 Answers
Save all your files on your computer before doing this.
Uninstall U3 from settings on launchpad.
Format your USB. Do not Quick format.
Reinstall U3: http://www.sandisk.com/Retail/Default.aspx?CatID=1411 (only works with Sandisk)
Drag your files into the USB. No more problems!
If anymore problems, reply!
Hope this helps!
Nicholas CHUM
Posted on Apr 25, 2008
How do I download word documents to cruzer flash drive
From Word, use Save As.... and point the file to your USB drive. You can also open two instances of My Computer and drag & drop from the PC to the flash drive.
May 09, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I need instructions how put my files on sandisk cruzer 8GB
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Jan 10, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
DELETE SONGS
hook it up to your computer and open up the files, then select the songs u want to delete and right click then select delete
May 13, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I would like to transfer photos' from laptop to cruzer using Window Vista! How to do that?
Hello..
Insert the Cruzer and allow your computer to acknowledge it. You will know this by going to "My Computer" and double clicking. You should see that the computer has assigned a drive letter to it. Double click that drive letter for the Cruzer. With that window left open, find were your photos are. Open the folder were the photos are located. With both windows open you can now drag the photos over to the Cruzer and drop them into the window for the Cruzer.
Good Luck
Jan 12, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk Cruzer Micro 8GB USB Flash Drive, destroying files
run a check disk on the memory stick - most likely a good indicator that the flash drive is on its way out as they normally have a life span of about a year or two.
Apr 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a SanDisk Cruzer USB 8GB that is only allowing me 1.33 GB of space - says 6.594 GB used and there's nothing on here - how do I gain that storage space back? tx
There might be a hidden file(s) on the drive that are taking up that space. Open the drive in My Computer, click Tools > Folder Options... On the View tab, click Show hidden files and folders. Then check the drive to see if any hidden files or folders are present.
You can also try formatting the drive. Right click the drive in My Computer and click Format...
Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cruzer Micro 8GB flash drive - no user manual
Plug it into the USB port. Press Windows-E to bring up the Explorer window, or start My Computer and open the removable drive.
You can then drag&drop files to/from the flash drive just as you do on the hard drive.
Feb 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Open Windows Explorer on your PC. You should see it there when you expand the "my computer" tree on the left side (click the + symbol next to 'my computer'). It will show up as a drive letter, depending on how many hard drives and optical drives you have in your system, it could be drive letter "E", "F" or even higher. It will probably say "Cruzer" next to the drive letter. All you have to do is drag and drop your files onto the drive letter. Simple, you don't need instructions.
Feb 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
MS word 2003 files not retreivable from Cruzer 8GB
I would suggest copy the file ot yoru desktop and open it from your desktop.
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
207 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
