Question about Maytag M7Q08F2ACOM Air Conditioner
The check filter light is blinking. I have checked the filter that is housed under the vents. It appears to be clean and free from tears. What do I do?
  • 6,927 Answers
Remove the unit,and dissasemble,and use a water hose and clean the unit on the inside and rid all debris,,careful not to bend the fins on the coil,but clean out the fins in the evaporator and the condenser,both coils,If this was at all ,helpful,please rate,thank you.
Posted on Jul 21, 2010
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
What does "check vent" light require that I do?
Clean your vent all the way from the machine to the outside of the house including the hood or louvres attached to the house outdoors. Don't forget the area behind the lint filter inside machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Apr 14, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
Oct 20, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
LG Tromm DLE2514W electric dryer: check filter light comes on when you turn the dryer on, but it otherwise seems to be working fine. The filter has been cleaned and the external house vent does not appear...
I suggest that you check the dryer venting hose and see if it might be clogged. You don't want to use the dryer with the filter light on. It could indicate a situation that could lead to a possible fire.
Oct 02, 2017 | LG Dryers
Hi. My Jag head lights have started this blinking thing. As I am driving they will blink for no apparent reason. There doesn't appear to be anything going on otherwise. Any ideas where to start?
I had an S-Type too, I found this blinking when battery charge was low. So my opinion is something wrong with charging, you have to check battery contacts, measure battery voltage and check alternator. A possible case, contact problem at ECU. THe ECU under the house of pollen filter at engine end. You need some car mechanic ambition to remove the house of pollen filter and to clean ECU connectors with contact cleaner spray.
Of course this is just my experience, no guarantee, this works at you.
Aug 21, 2010 | 2000 Jaguar S-Type
Maytag M7Q08F2ACOM Air Conditioner Logo
94 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
