Question about Broderbund American Greetings Creatacard Platinum 8 for PC
I cannot save a calendar as a pdf file. I get the
I cannot save a calendar as a pdf file. I get the message " printer not activated, error code 30" followed by "could not start print job" and then "an error occurred while printing". My printer works fine for all other applications so I do not believe it is the problem. Any suggestions? I use an HP PC running Windows XP version 2002 Professional, Service Pack 3. 2.21 GHz, 896 MB RAM. The printer is an HP 8150.
    President:
  • 2,340 Answers
When your want to save your file as .pdf extension, you have to select a "virtual printer" from your "Printers & Faxes" when you install the software you are using to save as pdf file.
If you select your physical printer install on your PC, the error message you mention will appear.
Hope it helps.
Posted on Jul 21, 2010
Problems saving a scanned item as a .pdf file
You will need to re-install Abbyy Finereader software.
Nov 28, 2013 | Epson NX125 AllInOne InkJet Printer
Will Calendar Creator 12 work with Windows 7 64-bit OS?
Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
Jan 19, 2010 | Broderbund Calendar Creator 12 for PC
Printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Jul 12, 2009 | Cannon Office Equipment & Supplies
My printer will not print.
When you get to the "Print" window, there should be the area where it says the type of printer. There is also a drop-down arrow. Click on the arrow and highlight your HP printer.
Jan 27, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Brother printer/fax/scanner MFC-240 C
i need to scan and save multiple documents under one pdf file. how do i do this and save all under one file?
Dec 18, 2008 | Brother DCP 130C All-In-One InkJet Printer
I can not make a pdf file off of printmaster version 18. I Just got a new computer Microsoft Vista and have installed the printmaster software and it will not allow me to do a pdf file. It keeps saying...
By the way did you get microsoft office with your new PC, if so you can download a "word plugin" from microsoft which will allow you save to PDF, there are also several "freeware" converters that can be downloaded. most install as a "PDF printer" you just print the file to the PDF printer rather than your default, then they give you an option to "resave" as a PDF
Aug 29, 2008 | Computers & Internet
Error message
The manual for the BJ-30 can be found here: http://downloadlibrary.usa.canon.com/cpr/pdf/Manuals/BJ30_user_manual.pdf On page 97 (105 of 183) it indicates your error message. Unfortunately, it does not give a way to resolve the issue other than bringing the device in for repair. I then came across this page which is a bit more descriptive with the error codes. http://www.uktsupport.co.uk/canon/bj/bj30.htm F12 is aPrintHead Temperature Error. It suggests trying to install a NEW print head. if the problem continues, the printer will require service.
Oct 17, 2006 | Canon LaserBase MF5650 All-In-One Printer
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
457 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
