Question about Motorola Mobility RAZR V3
Phonebook We just got a razor off ebay for my daughter. She went into phonebook and erased all the numbers there since they were not hers. Now we can not access the phonebook at all. what happened and how do we fix it?
    Sergeant:
    Champion:
  • 283 Answers
Hre's what you gotta do,, go to seetings, hit the initial set up, master clear, code ( 000000 ) the phone boot jst w8, then go again to menu, settings, initial set up, master reset ( 000000 )code, then w8, the phone will boot again, then it will all back to normal..gud luck...
Posted on Apr 25, 2008
Turn the phone off and flash a monster pack on to it. google razr v3 monster packs trust me had the same problem
Posted on Apr 24, 2008
The device is linking to my phone but it doesn't show the phone book and I can't make calls. It was making calls before I updated the phonebook. It was showing numbers I no longer use and I deleted it from...
Maybe you should try to store a number into the phone first, to see if it becomes available in the phonebook. If it does, it means you really cleaned more from the phonebook, than planned. Maybe you didn't erase it yourself, but it might occured with the update. Sometimes an update requires a cleaning-procedure first, deleting all previous stored data... In such case, the software should have warned you for this.
Oct 09, 2013 | Toys
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
How do I save telephone numbers to a uniden powermax 5.8 ghz cordless telephone
Phonebook (Storing Phone Numbers, Names, Distinctive
Rings and Speed Dial)
You can store names and numbers in your phone’s phonebook, search for names
alphabetically, and dial phonebook entries with just a few key presses. You can
store up to 100 numbers in the base and up to 100 additional numbers in each
registered handset.
The phone uses the same memory to store phonebook entries and Caller ID
messages. If the shared memory is already full, the phone will not store any more
phonebook entries. You will have to delete some of the Caller ID messages before
you can store a new phonebook entry.
1) When the phone is in standby mode, press phonebook.
2) Press the STORE soft key, S t o r e / E d i t N a m e appears.
3) Enter the name (up to 16 characters) by using the
number keypad (see the "Steps for Entering Names and
Special Characters" on page 44).
If a name is not required, go to step 4. <No Name> will
be used as the name.
4) Press the OK soft key to store the name;
S t o r e / E d i t N o . appears.
5) Use the number keypad, */tone/<, or #/> to enter the
phone number (up to 20 digits).
If you make an error, use the DELETE soft key to erase
the incorrect digits. When you are finished, press the
OK soft key to store the number.
6) If you store the phonebook entry from the handset,
D i s t i n c t i v e R i n g appears. Press volume up/down to
move the pointer to one of the Distinctive Ring options
and then press the OK soft key.
7) S p e e d D i a l appears. Press volume up/down to move the
pointer to select the Speed Dial location (10 locations:
SPD1-SPD0).
8) Press the OK soft key. You will hear a confirmation tone, and D o n e ! appears in the
display. EASY DOES IT! :)
Jul 08, 2009 | Uniden TRU9466 Cordless Phone
Can't enter phonebook numbers - Says memory full
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Feb 17, 2009 | Uniden TRU8885 Digital Answering Machine
How to unlock my firefly
With ATT sim in phone, Power on & wait to initialize.
Then, press & hold the green key until the "Enter Pin Screen".
Then, press red button 5 times until the exit is displayed.
Then press & hold the phonebook key til the "unlock code screen".
Press the phonebook key once then. To enter the code you use the green & red keys to scroll to the proper numbers to enter 6 digit code.
You scroll to the proper number and press the phonebook key at the number you select until the entire code is entered.
Once done, you will scroll to the "done" and press the phonebook key once.
Jan 10, 2009 | FireFly Cellular Phone
I need to erase all my contacts but don't have the unlock code to do it...
Go to Menu, Settings, Security (The code is usually the last four digits of your phone number), Erase All, and select Phonebook. This should clear out the entire Phonebook. You can also erase all of your downloads and pictures there.
Aug 26, 2008 | Cell Phones
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
RAZOR 2 RINGTONES
Use Master Reset option Its get reset your phone
you also use Master clear option , all your phone data get erased
and also ring tone
Feb 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
110 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
