Question about Refrigerators
Mr Freeze SA12863 Counter Top Ice Maker parts?
Looking for parts. Need water drain cap. We lost the gasket so now it leaks. Need 2 gaskets and a water drain cap for back-up parts. Can you help
  • 4 Answers
Call the phone number on the back of the machine.
sunpentown 800-330-0388
They helped me diagnose a problem and sent me easy instructions for fixing it. They also had parts I could order.
Posted on Jan 07, 2010
MY SAMSUNG ICE MAKER KEEPS FREEZING UP. WE TAKE IT OUT AND LET IT DEFROST AND THEN REINSERT IT AND IT WORKS FOR A WHILE AND FREEZES UP AGAIN.WHATS WRONG WITH IT
Posted on Jul 09, 2011
I have a Mr. Freeze counter top ice maker, it is leaking water from underneath, the side spout for emtying water out is broken. Does anyone know where I can take it to get it fixed. I live in La Mesa, Ca 91941, a suburb of San Diego, Ca. Thanks, Daisyrain643@msn.com
Posted on Aug 27, 2008
Water leaking from ice maker
Make sure normal drain line (located under the ice) is not clogged. Check gaskets and seals. Also make sure everyone who uses it closes the door completely and does not leave it cracked open. And make sure no one has screwed any thing into it and punctured through it. A screw alone will not keep the water in.
Feb 24, 2015 | U-Line Icemaker
Why does water freeze on bottom of freezer
Short answer: Because it's cold. It's what freezers do.
The long answer requires you to describe a bit more about what you've got and what is happening. What model freezer do you have? Is it a frost-free, or manual defrost? How old is it? Does it have a built-in icemaker?
Possibilities:
1) Your freezer is leaking some water from the ice maker or possibly the through-the-door water connections.
2) Your door gasket is no longer sealing, and humid air is getting in to the freezer, where the water condenses out and falls to the bottom of the freezer, creating ice. Make sure the door closes completely, that nothing stops it from closing, and that the gasket is tight; put a crisp dollar bill between the unit and the door gasket, and see if you can easily slide it around. If so, you need a new gasket.
3) Or, you may have a frost-free model and the hole where the water from the defrost cycle is supposed to drain is clogged. Pull things out of the bottom of the freezer, melt the ice, and see if there's a small hole. If so, make sure it's clear and clean; use a small brush, not anything sharp or abrasive.
Sep 07, 2014 | Refrigerators
Water leak under freezer door
the drain should be at the very bottom of the freezer. but it sounds like ur door gasket aint sealing all the way so ur freezer is trying to over compensate for the warmer air coming in
Jan 04, 2014 | Samsung RS267TDWP 26 cu. ft. side by side...
Possibility of a cracked block. how can i be sure/
Vehicles: Any with the above symptoms
A cracked cylinder block will cause either:
(a) motor oil contamination of engine coolant
(b) coolant contamination of motor oil
(c) white exhaust smoke, due to coolant seeping into one or more cylinders.
(d) more than one of the above
(e) all of the above
Oil infiltrating into coolant is easy to see - drain some coolant out through the pepcock at the bottom of the radiator, and place it into a styrofoam coffee cup. Oil droplets floating on top of the green (or orange) coolant are easily seen. Or visualize oil by looking into the top of the radiator through the radiator cap.
Coolant infiltrating into and mixing with motor oil will permanently damage the engine (seizing it up through loss of lubrication), and must be prevented.
A leak from above the front suspension is, as physicians like to put it, "nonspecific", with the most likely cause a water pump seal or hose/hose connection.
A leak from near the fire wall will usually be a heater core hose, or hose connection.
A coolant leak on the same side of the engine as the water pump is a leaking water pump or water pump seal until proven otherwise.
To rule out everythng else, here's the 1999 Honda CR-V Troubleshooting Guide for Coolant Loss/Coolant Leaking:
Priority Action Part Type Cause
1 Inspect Water Pump - Worn, Cracked or Leaking Water Pump, or Water Pump gasket.
2 Inspect Head Gasket - Leaking Head Gasket.
3 Inspect Radiator - Leaking Radiator Hose(s).
4 Inspect Radiator Cap - Worn or Damaged Radiator Cap.
5 Inspect Radiator Hose - Ruptured, Cracked or Leaking Radiator Hose.
6 Inspect Freeze Plug - Leaking Freeze Plug(s).
7 Inspect Intake Manifold Gasket - Leaking, Worn, or Damaged Intake Manifold Gasket.
8 Inspect Water Outlet - Cracked, Leaking or Damaged Water Outlet.
9 Inspect Heater Control Valve - Leaking or Faulty Heater Control Valve.
10 Inspect Radiator Drain Pepcock - Loose, Damaged, or Faulty Radiator Drain Pepcock, or Pepcock O-ring.
11 Inspect Engine (DOMESTIC ONLY) - Cracked Cylinder Block Leaking Coolant into at least one Cylinder, causing white exhaust smoke.
Dec 03, 2011 | 1999 Honda CR-V
1997 diahatsu charade ltd overheating no water leaks ,no water in oil, hopefully could be thermostat, were is thermostat located?
open the car hood. look at the radiator, and then the top radiator hose. follow that hose to the engine. the hose connects to the thermostat housing cap. under that cap is the thermostat. here's what you need: ratchet, and sockets, flat-tip screwdriver, scraper, pliers, a new thermostat (any auto parts store), a new gasket, and some gasket sealant. Question, how old are hoses? if 3 years or old, let change those also. 2 new hose, 4 hose clamps, and some coolant. If we're changing hoses with this, lets start. drain the radiator, and remove the hard hose first, the bottom. now remove the top.hose, and lets start the thermostat. remove the bolts holding down the cap, and gently pry off the cap. flip the cap over, and scrape it clean to metal(we want NO leaks). now reach down and remove the thermostat, and lets scrape the housing clean to metal. place the new thermostat in the housing, and lets put a thin coat of gasket sealant on the housing. place the gasket on the sealant, and pick up the cap. apply a little gasket to the cap. place on top of the gasket, and bolt it down. now hook the hoses(if your changing them)and let sit 30 minutes for the gasket sealant set. after that, let add the coolant, and water. start the car, let it warm up. when the new thermostat opens, add more coolant as need to top it off. Hope this helps
Jan 03, 2011 | Daihatsu Charade Cars & Trucks
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Mr freeze sa12863 where does the water go.
you lift lid and add water up to the bottom of the plasticslotted tray where ice cubes will be after made. I have a problem with sa12863 also, The water quit filling into tray? like line is plugged or pump quit???
Oct 31, 2008 | Refrigerators
I have a counter top ice maker. I can't seem to locate parts or find out if this machine even exists. It stopped making ice last summer. It cycles but does't add water to the cube maker. You have to add...
Magic Chef Counter Top Ice Maker.
just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
Mar 18, 2008 | Magic Chef Refrigerators
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
3,125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
