Question about Samsung Gravity SGH-T459 Cell Phone
My samsung gravity 3 won'ty charge in car
My samsung gravity 3 charges fine with my wall charger, but will not charge with my car charger. I tried it with another charger too, and that don't wotk either. I also tried charging another phone that uses the same charger and it worked, so i assume its not the charger. my sister also has a gravity 3 and has the same problem with the charger... whats the problem?
This problem cannot be fixed. You'd have to return your Gravity 3 and exchange it for another model. It's a known problem with Samsung and should acknowledge it and recall this product (or fix it with a software update free of charge). I spent a whole day at different T-Mobile stores and finally a rep showed me the technical bulletin on it and exchanged the phone.
Posted on Sep 14, 2010
  • Brookelynne Smith
    Brookelynne Smith Mar 07, 2014
    I don't have a gravity..I have a GALAXY PREVAIL
It charges somtmes but only 26% now it wont charge and wont turn on i have changed cords and plugs nothing works please help
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
charges-somtmes-but-only-26-now-wont-c42sdu52tip34gjoftdmfcql-4-0.png before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
The attached link is to an eBay listing that has a compatible wall charger sold in the US for $5.99 shipped free
LCD Battery Charger for Samsung Galaxy Mini GT S5570 i5510 S7230 S5330...
Nov 10, 2015 | Samsung Galaxy GT-S5570
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
Is my samsung gravity charging if it's plugged into the computer?
Yes, normally it will charge when connected to the computer. Give it a try and take a look at the battery icon on the phone to see if it shows that it's charging or using battery.
Nov 21, 2011 | Samsung Gravity SGH-T459 Cell Phone
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
I have a samsung gravity charger and the port came off so i tried to tape the poitive and negative wires to it but that didn't work so what's another way to get my phone charged other than buying a new...
purchase/find a micro-usb cable and connect to your pc- or if you have an ipod/iphone/ipod touch charger, remove the cable, and plug the micro-usb cable to that charger.
Jan 10, 2011 | Samsung Gravity SGH-T459 Cell Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
Samsung Gravity SGH-T459 Cell Phone Logo
615 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
