Question about Frigidaire Washing Machines
I have Frigidaire front loader washing machine model # GL TF2940FSI. It's about 2years old. To start the machine, you choose the cycle, push the start button, the water begins to run and the machine begins to tumble. Out of the blue, when I pushed the start button this morning nothing happened. The machine was on, but it switched immediately to ''pause.'' If I pushed the pause button, the machine turned off. If I tried starting without changing the cycle, it went immediately to pause. The water never came on nor did it tumble. I have checked the water supply and opened and shut the dispenser door and the washer door. Nothing changes the problem. I tried everything again this evening and the same situation. Help!
    Brigadier General:
  • 3,917 Answers
Hi
Most probably the start/pause switch is faulty. You need repair person to diagnose the unit thoroughly.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 21, 2010
Frigidaire won't go through cycles...
you need to call a repair service . the control board has failed
Jan 30, 2018 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire GLTR1670A front loader hot and cold
sears parts direct carries a lot of parts can be accessed online can start there or just search for frigedaire part number
Dec 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Mine just started - same Model ATF7000ES!
I have a Frigdaire Gallery model front loader. It is leaking underneath the machine. It is 7years old. Does this model haave a history of rusting out? Roy Ingham
Jul 10, 2008 | Frigidaire ATF6000ES Front Load Washer
FRont loader washer
try this,on next load use NO deteregent/soap.Please leave a rating.
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
