Question about McCulloch FHH18A Electric Pressure Washer
Detergent won't come out of washer - McCulloch FHH18A Electric Pressure Washer
  • 112 Answers
The pick up line sounds like it is blocked...probably by soap that has hardened in the line...take it off and clean it with hot water....squirt the garden hose up the line to help free up stuck gunge in line..take time with it and all will be fine.....remember to run clean fresh water thru soap pick up line after every use.
Posted on Jul 21, 2010
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
What is HE detergents
Special low sud detergent designed for high efeciency HE machines.
Feb 08, 2013 | Maytag NFW7200TW Front Load Washer
Detergent won't enter wash cycle
Clean the dispenser first and see if you noticed any blockages and then clean the unit itself in the dispenser area and use a little less than recommended and see if you notice any changes.
Jul 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Detergent won't go through siphoning tube
it will only draw detergent with the large black nozzle or the nozzle wide open with not draw with high pressure
May 20, 2012 | Honda Black Max 2600 PSI Pressure Washer
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
We have a duet washer wfw9200sq00 and it won't power on - just gives 3 beeps. I did get a F71 error code
F-71 user interface heartbeat failure, com failure between touch pad and central control.
You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
Service manual for duet with repair photos
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loading washer ghw9100lw2
Make sure the detergent/softner/bleach drawer is all the way closed and the small slider on it is secure.
Jan 12, 2009 | Whirlpool Washing Machines
McCulloch FHH18A Electric Pressure Washer Logo
530 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
