Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Beer tap I want to drill a hole in the side of my frigidaire refrigerator for a beer tap. I want to drill it on the left side as you are looking at the door. It's a standard freezer on top smaller fridge. Will I be in danger of hurting anything vital.
    President:
  • 1,218 Answers
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Posted on Jul 21, 2010
Testimonial: "Thanks for the warning. Is their a way to still do it without hitting the lines? Is it just one line running up and the rest of the side is clear?"
  • John Hall Jul 21, 2010
    Possibly two thirds the way back and as high as possible. It is a single tube that runs from the top front where the freezer meets the fresh food compartment to the bottom rear.
    Frankly, I never cut one open, but that's where it starts and stops.
Drill side keg
should not b any on either side,remember to insulate the attached beer valves
Nov 23, 2013 | Frigidaire FRT17G4B Top Freezer...
Door reversal on Whirlpool refrigerator
Look for a piece of plastic stuck in the holes.
Dec 19, 2017 | Home
I want to drill a hole in the side of my freezer for beer lines. where should i drill
Somewhere near the center of one of the sides is best.... but it can still be a guess and by golly deal....
Just keep the beer handy and if you hit a refrigerant line just down a few to make you feel better... :-)
heatman101
Nov 07, 2010 | Freezers
Can I drill a hole in the side of my westinghouse rj340m fridge .
the most fridges i have stripped the pipes are on the left hand side and the power wires on the right hand side but if the pipe is drilled thru it is only the oil cooled pipes it can be disconnected the important piper are at the back of the frige i hope this will help you
Jun 17, 2009 | Refrigerators
I want to switch the doors from left to the right side
Hi, The parts are interchangeable (hinges & handles)
You should have some small plastic plugs/caps that are covering the holes already drilled for the change. Once you remove the doors and then remove the plugs, just reinsert the plugs into the old holes and switch hinges and door handles to the opposite spots.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 26, 2009 | Frigidaire FRT17G4B Top Freezer...
I want to install two beer tap faucets in the side of my fridge
All of wires are located in the bottom. The side walls are just filled with foam. HAPPY DRINKING
Dec 05, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Making Modifications to my Hoover Orchid Collection 480L fridge
if it is a fridge and not a fridge freezer, then there should be no problem in drilling a hole thro the side
Aug 21, 2008 | Hoover Refrigerators
I have a Samsung RB215LASH refigerator/freezer that I want to use as a Keg Beer dispenser I know I can drill a hole through the door but due to the area it is goin into I would like to drill a hole in...
Apparently there is no solution, I have been told that it is not possible to drill through the side or the top of this model with out ruining it so I give up
Aug 19, 2008 | Refrigerators
I'm using a kenmore refrigerator as a kegerator and I need to know if there is anything I should be aware of on the side of the fridge walls as I have to drill a hole into it to attach the hose from the...
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
Apr 24, 2008 | Refrigerators
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
188 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
