Question about Briggs & Stratton Garden
I have a 24 hp briggs, model 445777, type
I have a 24 hp briggs in a troy bilt riding mower, model 445777, type 0231-E1,code030826YG. One of the adjustments on the intake valve came loose. I thought that I could check the other side and use the same clearances to reset the loose adjustment, It has no slack on the intake valve at anytime when you rotate the engine by hand. Does this have something to do with the compression release and how do I reset the valves?
  • 760 Answers
I believe this does have comression release. Make sure you're rotating the motor in the correct direction, as I think the compression release only works in one direction. Adjust the valve to .004 with the piston at TDC make sure it's on the power stroke. Turn the motor till intake opens, then when you continue to rotate crank, unitl valve closes and piston gets back to TDC. Adjust both valves to .004. Then do the other cylinder the same way.
Posted on Jul 21, 2010
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
I need owner's manual for troy bilt chipper/vac model # 47291
you can try a MTD ride on mower dealer or steelfort Engenering web site or mtd web site.
Sep 05, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
I need to remove the float bowl from a Troy-Bilt
on the bottom of bowl is a 3/8 nut remove that and gently tap the side of bowl ,there is a rubber gasket on top of bowl and it will stick
Jul 12, 2009 | Garden
Garden Logo
635 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
