Such blank screen mean hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such black screen problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
