posted by miller54 on Apr 22, 2008
I have a meade LX200GPS telescope. accidently attached to incorrect polarity of battery. Now autostar 2 handcontroller not functioning.
Solution #1
posted on May 22, 2008
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Fuji 17.5 Truss Design f/4.1 Telescope
Fuji 12.5 f/5 PDHQ Telescope
Vivitar (1607225) Telescope
Orion 120mm ED (284 x 120mm) Telescope
Orion 09969 (420 x 180mm) Telescope
Orion 150mm f/8.0 Reflector Tube Assembly (354 x 150mm) Telescope
Orion 254mm f/4.7 Telescope
Can you Help with these Telescopes problems?
Meade DS-2114 ATS (325 x 114mm) Telescope
Azmouth axle (lower mounting)...
I would like to repair the base... Answer This...
Discovery Channel Meade 8" LX90-GPS Telescope...
LX90GPS "finding...
LX90GPS "finding...
Hello I recently bought an... Answer This...
Celestron NexStar 80GT (189 x 80mm) Telescope
Telescope not self aligning by
Telescope not self aligning by... Answer This...
Repair Service
Find Telescope Repairman Near You:
