Question about Pure Digital Flip MinoHD F460 Flash Media Camcorder
Flipshare overcharged/ blown out... Can it be fixed?
I left it on a charger that wasn't a computer and it was overcharged and will not even turn on now. One red light was on one side can the blown out battery be fixed? Or replaced? Ect
    New Friend:
I did the same thing! Can anyone help???
Posted on Jul 19, 2016
Battery overcharge
first ask your self where you got it from and why you got it.
p.s. i am 9
Nov 03, 2013 | Tablets & eReaders
Can i over charge my mobility scooter go go pride
Yes you can overcharge a battery, it all depends on the charger your using. Most chargers are single stage chargers. Most scooters come with a single stage charger. My scooter has a built in single stage charger What this type of charger does is output a constant 24v @ 4amps.The problem is batteries amperage requirements decrease as the battery charges. An overcharge will occur when the battery is charged. It requires very little amperage to maintain a charge on a fully charged battery. A single stage charger like mine will output 4amps regardless of the state of charge of the battery. Batteries bring charged with single stage chargers loose their electrolyte. What happens is overcharged batteries break down the electrolyte into oxygen and hydrogen. So overcharging will cause a battery to "boil-out" its electrolyte. Batteries don't work without electrolyte. In the old days there were only single stage chargers. That was the state of the art back then. So to cope with the constant overcharging batteries had refill ports where you could replenish the electrolyte using distilled water.
Scooter batteries are far and away different from the lead acid of the 1970's. Scooter batteries are sealed, they are deep cycle, they use a glass mat soaked in gelled electrolyte. These glass mat batteries optimize the electrolyte used so they can use allot less of it. These newer batteries have a lot more power in a lot smaller package but they have a draw back, they must be charged properly. You can absolutely can not charge these batteries with a single stage charger. Actually you can charge with this device but you will loosed electrolyte each time you charge.
I use a three stage charger 24v @ 5amp. This charger s different from a single stage. Its what they term a "smart charger" it monitors the state of charge of the battery. As the battery charges it turns down the amperage. When the battery is fully charged the amperage is turned low enough were the charge is maintained. The entire charging process is designed to preserve electrolyte. In short this type charger will not overcharge the battery.
Click here to see the charger i currently use.
http://www.amazon.com/Sealed-Battery-Charger-3-Stage-Fan-Cooled/dp/B0051WHAU0
Jul 30, 2012 | Health & Beauty
I have flipshare on my desktop. It now says "your
look on your computer under either My Videos or My Documents and see if you find the FLIPSHARE DATA file. You can open that file and then see 3 files, videos, flipshare and previews. If you have an external hard drive, back all these up on that. If you don't, then try copying and pasting all three files or the one flipshare Data file somewhere else on your computer away from My Videos and my documents. that way when you uninstall the flipshare software it won't take those files with it, or shouldn't. then when you reinstall all, if the files remained, fine, if not copy and paste from wherever you stored them back to where they originally were stored by Flipshare. Your other choice is to take the videos you have on computer, put them into Windows Live Movie Maker and make a movie of them onto DVD. then you'll have them for sure. Just open the movie maker click on Add Videos & Photos and find the Flipshare Data file, then the video file and choose which ones to make your DVD. here's link to movie maker: http://explore.live.com/windows-live-essentials
you do have to create a name and login, but its all free and wonderful! just don't make your DVDs too large remember a regular disk holds 4.7GB 120 min. Have fun.
Sep 17, 2011 | Flip Video Flip UltraHD 8GB High...
My flipshare video has frozen-will not even turn off
Try holding the power button in for 10 seconds,this will reset the Flip usually.
If that doesn't work there is a pinhole in the bottom of the camera where the
tripod screws into,take a pushpin or something that small and push in for 5 seconds.
Then press the power button and it should reset.
It may be freezing because it needs the firmware updated,plug in your Flip camera to your computer and the Flipshare software will come up and check for new updates to the firmware.
Jul 14, 2011 | Cameras
I got a targus charger with a lot of charger tips with it. I found the one that works and it has been working for a while. Today i was on my laptop and it died. I noticed that the charger wasn't in. So...
Check to see if the charger tip is obstructed, dirt etc, check for fraying or a kink in the wire at either the charging tip or the wall plug. you can attempt to open it up to rewire it, i would recommend using caution, it sounds like as you got them in a pack of multiple chargers that it would be best to simply replace it.
Jun 24, 2011 | Computers & Internet
When I try to open flipshare on my computer, I keep getting a message saying (error)that says C:\users\pictures\setup_flipshare.exe is not a valid Win32 application. I have tried to uninstall all...
get and download revouninstaller ive linked to a portable version (http://portableapps.com/apps/utilities/revo_uninstaller_portable)
install that and open it.
let it find flipshare in the install programs,right click on flipshare and click uninstall.click ok for uninstall and select moderatesi
let it do its thing
restart your computer
redownload flipshare using a browser with a better download manager(chrome/mozilla firefox)
install it
Mar 07, 2011 | Computers & Internet
Won't turn on after charging
It happened exactly the same to me. What I did is just plug the cam to my Mac while Flipshare was running and just waited till it woke up. Took around 10min. :)
Jan 03, 2010 | Pure Digital Flip Mino Digital Camera
Flip software (Flip Share) quits unexpectedly on my Mac 10.5.6
HERE IS WHAT FLIP VIDEO SENT FOR A FIX:
Dear Suzie,
Thank you for contacting us.
We will need to try to uninstall and reinstall the FlipShare program on your Macintosh computer. To do this please try the following:
1. Please open your HD and in the search field type “3ivx”. Drag all 3ivx files into your trash can, and empty it. To uninstall FlipShare on your Mac, please go to MacIntosh HD > Library > Application > Support > Flip Video > FlipShare Uninstaller
2. Reboot the computer
If you are receiving the message, "Unable to update database file," when upgrading to FlipShare 5.6, there may be a corrupted file within your existing FlipShare database.
Please try the following to upgrade to the current version of FlipShare and import your videos into the application.
1. Copy your entire FlipShare Data folder onto your desktop or another drive
- the FlipShare Data folder can be found in "Username">Movies>Flip Share Data>
- ensure that you have copied all of the contents of the FlipShare Data folder and have secured a complete back-up of this file
2. Delete the FlipShare Data folder from your "Username">Movies>Flip Share Data>
3. Uninstall FlipShare
- MacIntosh HD > Library > Application Support > Pure Digital Technologies > FlipShare Uninstaller
4. Reboot your computer
5. Click on the link and follow the on-screen instructions to install FlipShare 5.6 onto your computer
For Macintosh systems (including Snow Leopard): http://download.theflip.com/update.theflip.com/app/fvsw/561/update/Setup_FlipShare.dmg
6. Once FlipShare 5.6 has fully installed, launch the program
7. Go to the Help directory and choose "Recover other FlipShare files..."
8. Click Proceed and select the Videos folder of the drive where you saved your FlipShare Data folder
- the FlipShare Data recovery tool will import your videos into FlipShare
Should the issue persist, please do not hesitate to contact us again so we may further troubleshoot.
Thank you,
Flip Video Support
May 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip share video application unexpectedly quits
Solved - I had the same problem.
The original "Flip Video For PC" software that came preinstalled on my Flip worked fine. But after being nagged to "upgrade" to FlipShare, I experienced the same crash problem mentioned here. Even worse, the FlipShare installation nuked the original program files from the Flip!
In my case, I think my computer's processor did not meet the minimum system requirements of the newer FlipShare software. The original "Flip Video For PC" software requires a 2Ghz P4 or higher; the FlipShare software says it requires a dual-core 4Ghz or higher. So when the FlipShare software tries to load the ippvideodecoder.ax module on an under-powered processor, it just crashes. Bad design.
I bet that most of the people posting this same problem here have processors that are "borderline".
Anyway, here's how to get the original Flip Video software back and re-install it on your computer:
Disclaimer: I assume no responsibility if you screw up your Flip or lose your videos. I can only tell you this method worked for me.
1) Use Control Panel, Add/Remove Programs to uninstall FlipShare and 3vix.
2) Download "Flip Video For PC" v3.7 from here:
http://www.theflip.com/app/prius/37/update/
3) Follow the written instructions here for formatting your Flip and reinstalling the software:
http://www.youtube.com/watch?v=JYc8N3dmxhU
Important: this guy tells you how to back up any existing videos on your Flip BEFORE you format it.
After formatting, I had some initial trouble with the installation not finding my (empty) Flip. Here's a workaround: the installation creates a folder called "FlipVideo Updater Support Files", and within that a subfolder called "files_to_install". Copy the entire contents of that subfolder to the root of your Flip. Re-run the installation and it should now be recognized.
4) Bonus: once you've got the old software reinstalled and working, you may want to disable the annoying "Upgrade To FlipShare" nag screen that bugs you every time you run the software. Simply browse your Flip and delete the following file:
[drive letter]\System\VIEWER\PD\checkForUpdate.txt
No more nag screen!
I hope this info is helpful to those who experienced the same problem. Flip tech support people are absolutely clueless.
best,
JohnB
Dec 25, 2008 | Pure Digital Flip Video Ultra Camcorder
Pure Digital Flip MinoHD F460  Flash Media Camcorder Logo
210 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
