This may happen if the Memory Stick is formatted in the Computer.
You may try formatting the Memory Stick in the Camera itself by using the FORMAT option in it.
If the issue persists even after formatting the Memory Stick in the Camera, then check whether a different Memory Stick works in the Camera.
If the other one works in your Camera then it must be the issue with the previous Memory Stick.
If the Camera does not work with a new Memory Stick, then you may try initializing it to check whether it resolves the issue.
Initialize option can be found in Menu items in the Camera.
If that does not resolve the issue, you may try removing the battery of the Camera for atleast one minute.
This should resolve the issue.
