Question about Poulan Pro Chain Saw 46cc 20"
Need fuel diagrahm for poulan chainsaw with priming bulb .took apart and dont know how the fuel lines go. 14'' saw
  • 487 Answers
Hi try this link for a pdf of owners manual: http://www.chainsawsdirect.com/manuals/Poulan_4620AVX_Man.pdf
Hope this helps
Posted on Jul 21, 2010
  • gregsharp4 Sep 16, 2010
    this is an owners manual there are no service diagrams
I replaced gaskets and fuel lines now when i prime bulb gas runs out of carb,also need factory settings for H-L and throttle,i know i messed up somewhere?realy need my saw running,thanks
take apart your carb--sounds like your carb diaphram is not installed right the settings should be
1.5 turn out low jet
1 turn out high jet
that should get it running then some fine adjustment once its running
Sep 04, 2015 | Poulan P3314 14Inch 33cc 2Cycle Gas...
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan Pro Chainsaw, PP3516AVX
is the cap vent plugged?
Aug 18, 2012 | Poulan Garden
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Saw is a 14 inch model 1950. Saw starts but won't run
Check the fuel filter, air filter and muffler for plugging. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel after several pumps? Hope this helps!
May 12, 2010 | Poulan 14" Chainsaw
Where can I get a diagram of a poulan 2350 16'' carb diagram ....I took it apart to replace internal hoses and they were dryrotted and broken and I do not know where to reconnect them
Typical Fuel System:
0295cbd.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel system components are shown but on multiple displays.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Dec 20, 2009 | Poulan Garden
When I prime my cainsaw ,gas leaks from the side near the handle. I usually prime it by tipping it on the side and depressing the gas bubble. Where the gas drips out then is on the side; the side is...
Cracked fuel line. You can find an IPL (exploded parts list) containing fuel components and some illustrations here:
"P3314 Gas Saw Type #" (Type is the - number of your serial number)
Poulan.com
Fuel components are on the "Engine Assembly" & "Handle, Chassis, & Bar Assembly" detail pages.
c828c16.gif Replacement fuel lines can be found at your local chainsaw seller/mechanic. They are different diameters.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro Chain Saw 46cc 20" Logo
292 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
