Question about Maytag MER5530 Electric Kitchen Range
Display intermittant for few weeks, now no display or oven control
My display was not functioning a few weeks ago. After pushing a few buttons or turning on a burner, then the display would lite up and allow me to use the oven, clock, timer, etc.
However nowadays I have no display at all, not even after the other tricks that worked before; now I have no display, clock, timer, or oven control... I'm not sure if it's simple wiring or maybe I need a new control panel/ display assembly. I would hate to spend $100+ on the display assembly when only a wire is bad.
Should I buy the repair manual and/ or display? Please help. Any advice is appreciated.
    Scholar:
  • 150 Answers
Real easy trouble shoot, check the wiring diagram out and find where the line voltage goes into the board. if you have voltage to the board and no display it is very likely a bad board also make sure you have ground pathway from the board. you can have voltage to the board but if no ground pathway then the board will not work. a cheapo meter from sears etc. will work
Posted on Apr 22, 2008
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
Help. Can't change oven temperature on Whirlpool when oven is hot.
YOU HAVE ISSUES WITH CONTROLL PANEL , NEEDS REPLACED
Jan 02, 2012 | Cars & Trucks
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
I have a new control panel that was just put in 2 weeks ago. I pressed the button start to long & the "Loc" came up on the display & it won't go off no matter what button I push. I've...
Did you replace the panel yourself? If it was a repairman it should be under warranty. Anyway I would think that after the supply has been turned off overnight the timer would reset itself. If that doesn't work and you don't want to keep mucking around with control panels and you can do without the electronic clock the control panel can be easily bypassed by a repairman. This will then enable manual oven operation.
Feb 16, 2011 | Ovens
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
Maytag MER5530 Electric Kitchen Range Logo
308 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
