Question about Proform Crosswalk 500 Treadmill
My control board does not work...buttons cant be pressed to engage the treadmill? I have a Pro-Form cross walk>
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Posted on Aug 13, 2010
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Have an old pro form 280, works good except for the info reading display. It comes on and I press the reset button, but it does not change. I put new batteries in it still no readouts.
1)exchange new batteries
2) clean the contacts batteries very well.
3) tight any plugs, cables, interconection such ribbon cables, and clean it
4) ADJUST THE REED SWITCH, see the diagram, clean, and tight the plugs very well, and proof.
5) if doesnot work, you problem with the display board vs main board. see the block.
God bless you
Sep 16, 2012 | Proform 280 Treadmill Walking Belt
Pro-form 370e crosswalk treadmill when the start button is pushed it starts up then stops immediately.
1)Lube the deck belt, this a problem by lack of maintenance, this produce enough friction and shut down the machine, by protecting the electronic system.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
May 15, 2012 | Proform 370E Treadmill Walking Belt
Treadmill stopped. panel still working - showing info.
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Jul 31, 2010 | Treadmill Doctor Proform 675Q Treadmill...
Pro form 520 treadmill
I lost the manual to the pro-form 520. How do you tighten the belt? Where can I order a new or find the on line manual?
Oct 11, 2009 | Proform iLog 750 Treadmill
Proform Crosswalk 500 Treadmill Logo
777 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
